Question about Edirol UA-4FX External Sound System
Screwd Hmm where to start i guess go with sound first.Bout a logitech X-530 5.1 surround installed then noticed ooops my sound card is 2 channel so i go buy a Encore Electronics 5.1 card model num.ENM232-6VIA .Im still not pushin all speakers the green is the only one producin sound.Im on a dell 2400 series.Also got a cam its phhillips SPC620NC it runs fine on software mode but if i go online to say like messenger its broadcast is black screened.
    Sergeant:
  • 395 Answers
Hi
There should be a control panel application to configure 5.1 for the sound card - also a system tray icon.
Is this Vista or XP?
re. camera - check you do not have dual output video and make sure you are using monitor 1 to display the camera.
Try downloading AmCap to see if camera is working OK.
Posted on Aug 17, 2008
Logitech X-530 speaker set plugged in as per instructions delivering sound from only front speakers and sub woofer. Nothing from centre and rears. XP system with ASRock ALiveDual-eSATA2 mother board....
Make sure the cables are plugged in the correct places on your PC. You may need to use the headphone out on the back panel. This depends on your audio card in your PC.
Aug 08, 2017 | Logitech X-530 5.1 Surround Sound...
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
Nov 02, 2010 | Logitech X-530 Computer Speakers
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY PC
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
Feb 07, 2010 | Logitech X-530 5.1 Channel Speaker System...
I hear music on stereo not 5.1 im with x-530 wtf is the problem??!?!?
HI , this means that your soundcard is not 5.1 Channel , and the speakers are , and 5.1 = Surround Sound , without a 5.1 Channel Sound card you will only be able to obtain Stereo out of it...
Sound cards are cheap these days , look for one and it will work perfectly.
Dec 26, 2009 | Logitech X-530 Computer Speakers
Only 2 speakers work even though its all plugged in correctly. Ive hooked it up to an i pod
Hi , Just to clarify is your Sound Card that you are connecting it too , a 5.1 Channel Sound Card?? if not then that is the problem as it is a 5.1 Surround Sound System..Reason for it only coming out of 2 speakers when you connect it too an ipod , is the Green Cable Doesnt Comply with all the Speakers , you need a 5.1 CHannel Sound Card to connect all the Cables into.A 5.1 Channel Sound Card looks like this http://www.dclstore.co.uk/images/products/genius-soundmaker-value-5.1-channel-sound-card-16-bit-pci-31720009100-l.JPG
I hope this helped bud ,
Have a Happy new Year :)
Another problem
Try to look in audio manager of your sound card for speaker fill (it's called like that on realtek soundcard) it shoud expand 2 channel audio to other speakers
Feb 01, 2008 | Logitech X-530 Computer Speakers
Logitech x-530 speakers connected to Highlander DVD recorder
YOu need to install the right drivers, for your sound and video card, latest. and Direct X9c.
Jan 13, 2008 | Logitech X-530 Computer Speakers
3 of 5 speakers not working.
Go into your computer audio system and make sure you are on you are not set on stereo
Oct 20, 2007 | Logitech X-530 Computer Speakers
There should be a setting in your sound card, assuming it is a 5.1 surround card, that allows the card to split the signal from two input connections (normally the normal speaker input'green' and the mic input'pink')into the required 5.1 output.
Feb 08, 2007 | Logitech X-530 Computer Speakers
Edirol UA-4FX External Sound System Logo
49 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
