Question about Homelite Mighty Lite Lawn Trimmer
Where is the fuel filter located on my model ut20024b string trimmer
    President:
  • Homelite Master
  • 1,545 Answers
Most all weed trimmers have the fuel filter located on the end of the fuel line inside the fuel tank.
Posted on May 25, 2011
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
Where is the fuel filter located on model ut20024b string trimmer
Hi, inside the fuel tank. You can hook it out using a piece of single strand wire. Hope this helps, regards Phil.
May 25, 2011 | Homelite Garden
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Poulan 32 cc string trimmer mod.# ppb100
Try checking the fuel filter, not sure of the exact location but should not be to hard to find. Try looking in the gas tank if it's not readily located. If small 2 cycle engines sit for any length of time ( 30 days or so) with fuel in them the filters can become clogged. If your not going to use it for extended periods or storing it for the winter make sure you drain the fuel tank and run the carburetor dry.
Nov 07, 2008 | Poulan 25cc 2-Cycle Gas Powered String...
Homelite Mighty Lite Lawn Trimmer  Logo
166 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
