My color on my monitor is messed - Computers & Internet
Check the vga imput cable, if it has a bent or missing prong, then it will not have a color and will not display properly.
Posted on Aug 16, 2008
SOURCE:
LG Flatiron monitors.1st one on Dell pc works great. 2nd one in same household to Compaq pc still flashes faint pink on parts that should be white.
Probably just some color balance is of. Reset white to something different on the compaq. Try downloading nvidia-settings and see what happens when you mess with color balances. Mess around with some settings til it looks right, or see if you can reset the white balance to a different preset on the monitor's menu
Oct 26, 2009 | LG L1920P 19" LCD Monitor
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Color are messed up white is pink
Is it messed up if you plug in an external monitor? if no then something is messed up in the internal connection in the computer and you would need to take it apart and replug in the video cable on the back of the monitor panel.
Jun 14, 2009 | HP Pavilion dv6000z PC Notebook
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Color calibration Envision 17" monitor
Return to dealer for service, This is a common problem of a bad backlight on LCD Monitors. If it is on the top comming down it is the top lamp,from bottom up is the bottom lamp. Hope this helps you .
Dec 17, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Color goes off
If your color is messed up on your display also then I think you need a new monitor. Why don't you try using a monitor that you know works and see if you have the same problem. Then let us know the results or the answer so we can have a little more to work with.
Dec 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Lcd monitor messed up
hello do you still have the monitor maybe i can trade you something for it i can use the parts to fix a unit i have let me know thanks
Jun 29, 2008 | ViewSonic VX2235wm LCD Monitor
Pinkish monitor
the monitor is on its way out ,
time for a new one
Terry
Mar 29, 2008 | Computers & Internet
Monitor Color
Go to dest top right click, will show up a box find the color setting you want for your computer.
Nov 24, 2007 | Dell E173FP 17" LCD Monitor
Screen flicker, color swirls
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Jan 22, 2007 | Neovo F-417 17" LCD Monitor
Open Questions:
Computers & Internet Logo
111 people viewed this question
Ekse
Alun Cox
