Question about Sony Cyber-shot DSC-W55 Digital Camera
Sony dsc w55 i was trying to clean the camera whilst the zoom lens was out and must have pressed to hard and when i press the power button it wont go back in and i can not take any pictures, please help as i need my camera to work as i am going on holiday on sunday!
  • 6,831 Answers
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on May 25, 2011
Where is the reset buttom on Sony Cyber-shot Camera model DSC-W55
It's not a single button.
Press the MENU button. Press cursor-right, select Setup (toolbox icon), press cursor-right. Use cursor-up/down to select "Initialize" and press * at the center of the cursor pad. Use cursor-up to select "OK" and press *.
Nov 20, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Cyber-shot DSC-W55 Digital Camera: sonyW55 lens only comes out half way ,can not take...
1.Please reset the Camera to its factory defaults and check if it helps.
2.To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
If you're not able to access the menu option in the Camers, try this:
Power Reset the Camera and check if it helps
To Power Reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 30 seconds.Then, reinsert the Battery Pack after 1 minute and check if that helps.
Please Power Reset the Camera and I am certain that it should resolve the issue. If the issue still persists after Power Resetting the Camera, then it requires service.
http://eservice.sony.com
May 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When the camera is turned on , the zoom tries to adjust twice while the displays says" access" then it Says" Turn the power offand on again" Following the instruction does not solve the problem, we can see...
The error "Turn off the power and on again" shows when the zoom motor start malfunction, If you want to repair by yourself and have experience then change the optical zoom motor it will reduce your cost. Otherwise you can change complete lens block assembly, both part and description is given below for your help and convenience:
Part No. Description
1-788-363-11 OPTICS UNIT (ED13A) (complete lens block assy)
2-673-648-01 ZOOM MOTOR UNIT
You can contact any expert or Sony Service Center to change the above said part and your camera work fine again.
Thanks for using fixya.
Jul 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc - w55
the part which comes out when the power is on might have got stuck .. there may be some dust particles. just blow over it or vaccum it..
Dec 26, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Wont zoom
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Playback button on Sony Cybershot stopped working
you have pressed that button hard for many times.. or it may be old..
Jul 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Access black screen problem
try this!
1.turn on the unit and switch it to play mode( by pressing the button next to th viewfinder.
2. press the menu button
3. select setup (the option with the toolbox icon)
4. inside setup look and select for setup 1(toolbox icon with a number 1 at the bottom)
5. then select initialize and select OK to every ptompt,
6. then it will pop up clock settings.
if this will not work then it would be better to hav the unit checkd and repaired by an authorized servicer. sony 1800-222-7669
Jan 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Digicamera model S820
My camera had a similar prob. Instead of pressing the shutter button half way just press it all the way down and see if that works.
Jan 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
