Question about Brother MFC 7840W Printer
Black line occurs when I auto feed on copying. NOthing else. Thank YOu.
  • 610 Answers
Try lifting up the document feeder and look for a piece of glass just to the left of the big piece of glass you put your originals on. Check the small glass for any spots of dust or anything on it and try cleaning that glass with windex.
Posted on May 25, 2011
I have a black continuous line down the right side of my paper. This only occurs when I feed the paper, it does not occur when I place paper directly on glass to copy. Can you please advise what I nee
there is a small glass strip that the paper feeds across. It needs to be cleaned. Raised the lid like you are about to place the document on the glass and look for that strip. Scrub it with a lint free towel, use IPA (not rubbing alcohol) to help cleaning. Dont use soap.
Sep 29, 2014 | Office Equipment & Supplies
Copies nothing but solid black paper
Printing from system is OK? Do scan and check.not proper ? check CCD unit & cable..
Suspecting 80% CCD unit(Unit under flat bed glass moves while scan or copy with lamp)
20% cable(flat ribbon cable connected between CCD unit & Formatter) see the snap shot for easy recognition of CCD7_15_2012_3_12_34_am.jpg
Jul 13, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Sharp Copier AL-1631. Copies with a black line (which moves positions on the page each time). Checked the manual and cleaned the part that it told me to. That did nothing to fix the problem.
If it only happens when using the document feeder (if fitted), then the small glass on the right hand side needs a clean ( normally tippex), if it occurs when copying from the glass and doc feed then your charge corna needs cleaning
Dec 01, 2008 | Sharp AL 1631 Copier
When making a copy there is a black line on the printed copy. I have a HP Photosmart C6200 all in one series
Look for white out or anything else on the platen glass. If this is occurring when feeding through the ADF. It is probably dirty rollers under and inside the ADF unit.
Nov 15, 2008 | HP Office Equipment & Supplies
Black line vertically on scanned/printed documents
This problem can be caused by a number of different issues. If it occurs when you copy, check the scanning glass to see if there is any dust/gunk on the scanner glass. Also if you machine has a document feeder than you need to check the **** glass that the paper feeds past.
If it occurs when you print than you probably need to clean your printer. Check your manual for exact details on how to clean your printer but in general it could be on a paper feed roller or it maybe something on the drum. If you let me know what printer this is happening on I can direct you to a manual if needed.
Henry
Apr 22, 2008 | Office Equipment & Supplies
Black line in auto feed
If you lift the scanner cover, you should see an area on the right end of the platen glass marked at the edge with arrows as Read Area. This is the area used when documents are scanned through the auto feed. Make sure that the glass is completely clean in this area, as any dirt will show up as a line on the copied image.
Apr 18, 2008 | Canon imageCLASS D880 All-In-One Laser...
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Brother MFC 7840W Printer Logo
664 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
