I have a compaq presario and it's telling me that my hard drive is failing. How can I fix this with an immediate remedy or would I have to repace it?
  • 5,568 Answers
You need to back up very soon; your hard drive uses S.M.A.R.T. technology and the number of retries to read or write has reached some built-in limit indicating that the drive surface or the heads are no longer dependable. If your Presario did not come with a set of restore disks, you must make them yourself from the instructions in the Help file if you have not done it already.
If you wish to be better informed on this technology, click on the link below:
Posted on May 25, 2011
  • 916 Answers
The hard drives have built-in circuitry which monitors the health of the drive. In simple terms, when data is written to or read from the hard disk (a constantly spinning disk with a magnetisable surface), the circuit monitors how often errors occur and if this becomes more frequent then it will signal a warning which the operating system or BIOS can read.
The safest thing to do is back up your important data and replace the hard disk.
There are utilities which may be able to carry out a low level format of the drive, which obviously loses all your data any way, and this may allow the drive to work for a bit longer but it would not be reliable.
Virus? Hard Drive Failure? Help Please!
This is because the Hard Disk Drive has failed and you need it replaced. If your warranty is still valid, take it back for repairs or buy another hard disk drive altogether.
May 19, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
MY COMPAQ PRESARIO WHEN TRYING TO RECOVERY STUCK AT 26%
I've seen this happen multiple times when a hard drive is failing and getting frequent I/O errors. Unfortunately, the fix is to replace the hard drive and restore the system from DVD or CD recovery media.
Hopefully, you created recovery disks and stored them away for a rainy day such as this. If not, you can usually purchase recovery disks from the manufacturer for a (hopefully) reasonable price.
Dec 30, 2012 | Compaq Presario CQ56-115DX Laptop
Hello, My Compaq Presario 750US will
The motherboard of your laptop might have encountered a short circuit. If you've already removed and reseated all possible removable parts and still get the same result, purchase a replacement motherboard or check if it is still under warranty.
Good luck.
May 17, 2011 | HP Compaq Presario F750US
When i turn on my laptop a warning notice comes on screen immediately saying smart failure predicted on hard disc 0:ST9160310AS-(PM). Warning immediately back up your data and replace your hard disc drive....
It means exactly what the message says.
The hard drive is going to fail in the near future. I recommend you back up your data before the hard drive fails completely.
When the hard drive fails, replace the hard drive, and use your Compaq recovery disk to install Windows and the device drivers plus your programs to get the laptop working again.
May 01, 2011 | Acer Computers & Internet
My compaq presario did not boot up properly and told me that the hard-disk is not found. how do i fix this?
Most likely its already a hardware problem. If you want to make sure try to reseat the hard drive. If still the same, means the hard drive already fail. At the bottom of the machine look for a cover with the small logo near the screw heads that looks like a 3 cd's that stack together that's the hard drive bay.
Apr 19, 2011 | Compaq Presario CQ62-215DX Laptop
Hello, when I boot my computer it tells me computer fan failure, please service for repair immediately before further damage is done. It will shut down in a couple seconds. Then it shuts down. The fan...
First test your CPU then tast all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 02, 2010 | Compaq Presario Fan
Running home ed windows on presario v2000 (now five yrs old) windows loads but harddrive continues to run inefectually - cant access programmes etc - then screen turns blank after approx 20-30mins - hard...
Backup your programs immediately to a thumb drive or external HD. The hard drive may be on the brink of failing. You can replace a hard drive, it's your information thats on it that you may not be able to if it totally crashes!
Mar 20, 2010 | HP Compaq Presario V2000 Notebook
Not able to open windows
Sounds like a hard Drive problem. A virus actually. The Best thing to do if Safe Mode Failed is the Repair Your system, to do this insert your XP CD and wait until it says 'Press any key to boot CD' Press any key and follow instructions to repair windows. If it works, run a virus scan immediately. If Not, take it itno a computer technitian to look at it if you want the stuff on your Hard Drive, of if you feel you don't care too much just wipe the Hard Drive and Re-Install Windows XP. just do the same thing as repair but instead follow the instructions for Installing XP and choose either Clear or Erase Hard drive if you don't want the info or choose don't clrear or Erase if you really want stuff from your hard drive, But run a Virus scan Immediately asap.
Hope This Helps
Nov 18, 2008 | Compaq Presario M2000 Notebook
Open Questions:
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
