I have a brivas mps ducted heater that cycles between start up and prepurge mod. the control unit with its lcd display runs like this --- aprox control unit on heating ignition ignition (burner lights and splutters) lights again (splutters) unit goes to pre-purge mod i assume to clear the gas out of the burner chamber then it attempts to light agin ??????
  • 43,501 Answers
If you are getting a sputter flame then the gas air mixture is not right....usually this is because the gas pressure from the gas valve is either too low or too high, but that can also be because the gas pressure into the gas valve is not correct.
To troubleshoot this properly you should use a manometer and check the incoming gas pressure as well as the gas pressure in the manifold. Sometimes adjustments can be made by a tech. on site and other times the gas co. may have to make the adjustments.
Once the gas pressures are verified then air adjustments can be made on the burners to get them burning correctly.
heatman101
Posted on May 26, 2011
Brivis multiplex he20e
MPS HE20E is a gas heater. So the unit should need a pilot to be re-ignited. This will happen automatically once you press the ON button on the controller. Assuming the gas supply is normal this should happen immediately. The unit attempts re-ignition 4 to 5 times but if the pilot does not turn on it will display an error code on the controller. Take extreme precautions when dealing with gas appliances. Make sure you call a technician if unsure.
Aug 21, 2014 | Heating & Cooling
Delfield coldpro freezer mod#f2fh evap frozen. what is most common problem?
Look for: defrost timer not moving, i.e. locked up.
Contacts on defrost timer not making circuit to the defrost heater.
No power to heater.
Heater not working, open element, burned out, etc.
Defrost terminator defective. Not letting unit stay in defrost cycle. Could also interupt power to heater.
Defrost cycle too short. should be about 20 to25 minutes long and 4 times a day.
Evap fan motor not running or running inconsistantly.
Evap fan running in wrong direction or wrong speed.
Evap extremely dirty which blocks air flow.
Improper freon level.
I'd start with these items. Let me know if I can be of any further help.
Oct 18, 2010 | Delfield 032-F2FH ColdPro Solid Door Reach...
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Apr 30, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
When I turn my heat on in my Honeywell programmable thermostat the fan kicks on for a couple of seconds then shuts off before my heat starts up. How can I get rid of this initial fan start up?
Sounds like that is a 'prepurge" on your furnace. Remove the doors on the furnace and look at the wiring diagram it will usually say on there where to place or move a small jumper from a 0/30/60/90 second prepurge. On some models this may not be adjustable. If your brand is a carrier this may be the case.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Heating & Cooling
BRIVAS DUCTED HEATER FAN RUNS BUT NO HEAT
It sounds like a bad or tripped limit switch. The limit switch is a small disk about the size of a penny with 2 wires attached. There will be a small button between the two wires. Press firmly to reset it. Depending on your unit there could be 2 to 5 of them to reset. If they aren't tripped, then one by one, take a small jumper wire and jump them by bypassing them. You will eventually come across the "bad" one. If you can't reset it, then you will have to replace it. There is also a limit that can not be replaced that is located on the heat exchanger wall. Bypass it only temporarily to see if it is bad as well.
Apr 06, 2009 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
