Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer gives an error code of uL everytime we use it. What can it be?
    Problem Solver:
  • 6 Answers
The tub and drum are locked on the shaft and will not unlock, you can tell if the tub and wash plate rotate together and the drum keeps trying to unlock by jiggling back and forth. This means the tub is stuck on the shaft and needs a bearing kit, I don't know how long this job takes as I have not done one yet but I will find out in the morning as I have one of these to repair, I will let you know how much of a job this is after I have done the job, god help me, I am really not liking cabrilos at all.
Posted on Oct 25, 2012
  • 1,116 Answers
Unbalance Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
Posted on May 25, 2011
3 Suggested Answers
  • 19 Answers
SOURCE: my washer seems to be off balance everytime it
You may only be running a few items and that will cause it to spin out of balance. Try a full basket of like weight clothing. Be sure to check the drain hose...it should only be inserted into the wall or drain about 6-8 inches or it will pull water back in the machine causing this problem. That is a very common issue.
Use 2-3 tbsp of liquid detergent or below line one on powder in this unit as it uses very little water. Use only detergent labeled as HE detergent or you will get foamy water and the pump, bearings, seals will fail. Usually that will result in a loud whining noise or the sound of a train/jet in the laundry room!
You will need service for that one as it is not for the normal handy-man/woman.
Posted on Feb 14, 2011
KevinWhite
  • 1902 Answers
SOURCE: I have a whirlpool washer.
Hello & Welcome to FixYa
UL error means unbalanced load, If the load is unbalanced, the washer will display this code while running an imbalanced load correction routine at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load then close lid and press START. Please get back to me if you have any other questions.
Kevin
Posted on Mar 21, 2011
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
Aug 14, 2016 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
UL bravo error code
Unbalanced load? Don't over stuff the washer. The load sensing moves the drum back and forth at the start. If it can't balance the load it will err.
Oct 16, 2013 | Maytag Bravos MTW6600T Top Load Washer
Sears washer keep showing ul code ..why
That means that it has been overloaded. IF it is giving this error and there is nothing in the machine then it has a bad sensor. It could also be that the drum has broken loose from the shocks or springs that support it.
Mar 24, 2013 | Sears Washing Machines
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Having code ul
In most casest this indicates a problem with the software in the machines main control circuit board, replace board with this part number 26-110-8564393R and this should resolve the problem part cost about 114.16 if you like go sears parts direct .com or call parts directly at 800-573-6456 also vist vist manage my life .com and ask for assistance in installing the board thanks
You can try to clear the Error Codes;
  • Unplug the washer for 1 to 2 minutes.
  • Disconnect the U.I. (touch pad).
  • Plug the washer back in for 1 to 2 minutes.
  • Unplug the washer.
  • Plug the U.I. back in and then plug the washer back in. Codes should then be cleared.
Most of the time if no mechanical faults can be found the CCU (Central Control Unit) needs to be replaced. I would recommend running the diagnostic cycle first (see image below).
This is a very labor intensive do-it-yourself project, it involves extensive tear down of the washer. If you are not already sure you can perform these checks safely and competently, refer this work to a qualified professional. Working with live electrical current can be very hazardous and possibly deadly. Testing voltage output requires working with electrical current. Do not attempt these measurements without the proper tools and safeguards. First you will need to see if the washer gives that "UL" error while running the washer empty. Start a load with nothing in the washer. If the "UL" error comes up there is a mechanical issue or bad CCU. If the "UL" error does not come up there is most likely a loading issue. A common problem that causes a "UL" error is mechanical friction. I.e. something keeping the basket from moving as designed. You will need to remove the basket from the tub. I have included an illustrated set of instructions (See below). Check between the basket and tub for foreign objects such as socks or other small laundry articles.
Sep 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
763 people viewed this question
Dan Webster
Dan Webster
Sal De
