Question about Microwave Ovens
I have a whirpol microwave mh7140fxb that quit working and when I replaced the fuse and turn it on it runs for a second then blows again. Any idea whats wrong?
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Dual Wave II microwave oven blowing fuse
It sounds like a shorted high voltage capacitor, a fairly cheap fix. But if it's good, I would suspect the high voltage transformer.
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 06, 2008
AlmostBob
  • 550 Answers
SOURCE: fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Posted on Oct 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: keeps blowing fuses
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
You can order Panasonic parts from Tritronics here or by calling 866-779-5835, but if you don't find what you're looking for there, try here.
Posted on Nov 09, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Microwave Blowing Fuse. Fixed. After Day, Fuse Blows Again.
Hello there:
If you have all ready changed out the fuse and it has happned again i would first check to see that the fuse is the right one for the machine (i am sure that you did this but please recheck ) next i would look at the controle board as the next culprit it maay be failing expecially if there were any pops ar sparks that was noticed before the initial failure.
Also check to see if all of the wires by the board a re not loose or looked burned ar if there is any grease or anything like this around the area
And finally check to see if the plate is turning ok and not sticking cause this would cause the microwave to overload and it wil make every fuse you put in there fail after just a couple of uses ok
SO please try all of these things that i have explained to you
I hope this is very helpful for you.
Best regards Michael
Posted on Dec 12, 2009
Whirlpool Microwave (model WMH1164XVS-1 ) does not turn on
This could be a lot of things. IT might be a capacitor or diode. MY money is on the capacitor. Since it works for a minute before it quits.
May 06, 2013 | Microwave Ovens
Hamilton Beach hb-p90d23al-dj keeps blowing fuses
If the microwave oven is less than 7 years old the problem is in the magnetron, " the most expensive part " or the inverter board, either way costly adventure, good for target practice.
Aug 13, 2012 | Hamilton Beach Hb-P90d23al-Dj Microwave...
It just quit. is there a fuse? MW8102SS
most micros have either a 15amp or 20 amp ceramic fuse at the top behind the touch pad. cover has to be removed. don't touch the hv capacitor. check fuse for continuity if none replace with like fuse. if it blows again you have another problem.
Oct 04, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Fuse keeps blowing. Why?
The HV diode in the power supply for the magnetron is probably shorted.
Jul 18, 2009 | Microwave Ovens
Ge XL spacesaver Microwave blowing fuses
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Jan 15, 2009 | GE JVM1630 Microwave Oven
Fuse keeps blowing.
couple questions -
60watt bulb and a
375watt fan
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave emerson not turning ON
That makes it sound like a bad high voltage transformer.
Do you detect any burning smell?
Do the windings of the high voltage transformer seem blued or blackened?
They should be copper colored or maybe a little darker due to the varnish.
Apr 01, 2008 | Emerson MW8775W Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
