Question about Zebra 105Se Thermal Printer
I have a Zebra 105se printer. When I attempt to print labels, I am using bartender 9.4 to create the labels, the printer will not print using the full label. Instead it uses only the last inch of the label. It just doesnt seem to maintain the same format I setup.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Check to see what printer driver you are using. If you are using Seagull Scientific Bartender, you will need the printer driver from Seagull Scientific for it to print properly. You can download it from the Seagull website. Hope this helps!!
Posted on Aug 30, 2011
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
I switched a Zebra printer from one computer to another. It used to print on the previous computer, but it will not seem to print on the one I switched it to. Do I need to install the printer? I do not...
You need to install the printer driver for Zebra 105Se as well as label software (if you are using it). If you are using label software, BE SURE TO USE THE DRIVER PROVIDED BY THAT MFR, as they are not interchangeable. If you are not using label software, use the ZDesigner driver from the Zebra website.
Jun 13, 2011 | Zebra 105Se Thermal Printer
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Our Zebra 105se printer has started missing labels. For ex., it will be printing a batch of 40 and every third or fourth label it shoots out an empty. sometimes it puts out two empty labels but in the end...
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Jul 13, 2009 | Zebra 105Se Thermal Printer
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
237 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
