Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
Message on PC screen tells me "printer is busy"
  • Official Brand Answer
  • 3,344 Answers
Make sure there are no print jobs stuck in the queue. If you're using Windows, go to the Control Panel > Printers > double-click on the Lexmark print object. Delete all print jobs pending. If you can't clear all print jobs, follow the steps below:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Reboot your computer. Then, try to scan again.
Posted on May 26, 2011
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
Screen message "Cannot connect to PC". Printer
Verify OS support,un install & install drivers once again with original CD, it will resolve the issue.
Sep 24, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Canon MX860 is out of ink and wont let me use the scanner. I have tried what this man suggested, "After you get the Error Message, press "OK" just to the right of the LCD screen on the MX860...
Call Canon Printer Support Number 1-800-243-0019 for Canon Inkjet, Pixma and Laser Printer Drivers. Contact Canon Business Support Number for your Business Printer.
Apr 19, 2017 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
-There seemes to be no contact between my lexmark x3470 and my pc.(w.vista) -Bouth (2007) have worked quite well together before, exept some trouble when low on ink. -Just put inn a new cartridge(1) of...
Uninstall the printer form the pc an disconnect it. Reboot and reinstall the software and wiat for it to ask for the printer to be connected. Follow the on screen instructions
Jun 29, 2011 | Lexmark X3470 All-In-One InkJet Printer
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot...
"Power off" printer > Press & hold 'ENTER' > 'Power on'. Continue to hold 'ENTER' key only till "Program storage intt." (or similar nsg.) appears.
Wait & Let the unit boot to "Ready" message in the screen. Reload PC with device driver. Try to scan. If error persists Formatter PCB may need replacement.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
Trying to scan a picture into my computer; printer screen says "requesting scan" for about 2 minutes, then it says "scan request failed"
If you simply plug the new All-In-One into the USB port on the PC, a "new" plug-and-play event will install a new copy of the printer driver. To confirm that this is the cause of your issue, look for two copies of the printer in the Printers folder.
What to do
To resolve this issue, restart the PC. Scanning should now work as expected.
Oct 28, 2010 | Lexmark X5495 Printer
I have a Lexmark E352dn printer. The screen showed that the Photoconductor needed replacing which I have done. However the screen still shows " 84 Replace Photoconductor " I have removed and...
the problem is that you need to reset the counter of the photoconductor unit. From the official site of lexmark, i find this solution.
Step Action 1 Enter the printer's Configuration menu:
  1. Power off the printer.
  2. On the printer's operator panel, press and hold the select button (pattlnk_11202006_2142-select_button.jpg) and the back button (pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif).
  3. Power the printer back on while keeping both these buttons held down.
  4. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons.
  5. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen.
2 Press the right arrow button (pattlnk_4122007_1837-right_arrow.jpg) until you see Reset PC Cnt. Press pattlnk_11202006_2142-select_button.jpg once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg again.
The printer will display a Resetting PC Count Value message and go back to the previous screen.
3 Press pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif once. 4 Press pattlnk_4122007_191-left_arrow.jpg or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
If the counter has been reset correctly, the printer should return to a Ready prompt.
5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that:
  • The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer.
  • The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer.
If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information.
Dec 02, 2008 | Lexmark Office Equipment & Supplies
Can't scan on the HP OfficejetJ4580
Uninstall everything that has to do with your old HP printer, drivers, photo processing, etc. Reinstall software with J4580 printer. That should open HP Digital Imaging Monitor where you can set scanning options. Plug printer into the back opf your computer. Plug power supply directly into the wall socket.
Nov 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
Cant scan from hp 3110 photosmart printer
You are having hardware communication problems caused, very likely, by driver installation troubles. Go into CONTROL PANEL and then SYSTEM and then DEVICES and look for the scanner there under IMAGING DEVICES and check to see if it has an exclamation mark next to it, or if any other device has this mark, meaning that drivers are not installed for it. If there is no scanner but you have a warning icon labeled UNKNOWN DEVICE, this is the problem. If you find any non-functioning hardware devices, this is probably it.
Try this as a fix. Unplug the cable to the printer/scanner.
Go online to HP and download the latest drivers and utilities for the scanner/printer and save them to your desktop.
In CONTROL PANEL, open ADD REMOVE PROGRAMS. Scan down and remove (uninstall) anything related to the HP printer or scanner, everything. Then reboot. Then install the drivers and utilities on your desktop you saved previously, plugging in the unit when prompted to do so. If you are never prompted, plug it in at the very end when everything is installed. If this routine fails, try rebooting the system without the HP scanner plugged in, wait for a complete start-up, and then plug the scanner into a different USB port and follow the directions on screen taking note of any failure messages. PS: the scanner/printer needs to be powered on through all of this, of course. :>)
Good luck
Nov 16, 2007 | HP Pavilion dv4000 Notebook
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
145 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
