Question about Dishwashers
Our whirlpool will not drain,
Our dishwasher will not drain at end of wash
  • Anonymous May 18, 2009
    dishwasher will not drain at end of cycle
  • 88 Answers
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
My Whirlpool gold dishwasher will not drain completly, and if it does, it's very slow
If there are no obstructions in the discharge hose then I belive that the pump is most likely the blame. Something may be caught up in the impellers of the pump not allowing it to create suction. You can also look to see if the electrical connection on the pump has in some way become disconnected via a plug or loose wire.
Jan 04, 2015 | Whirlpool Gold GU2475XTV Builtin...
Whirlpool dishwasher does not drain. Wash arm operates correctly
Check the drain hose under your sink make sure its not crushed or kinked if you have a garbage disposal the hose should go up into it at a 90 degree angle if not 180 degrees into your sink drain line
Jul 25, 2012 | Whirlpool Dishwashers
Whirlpool ADP6940 Dishwasher The CAP at the below of the washing is lost. Due to this water is leaking at the end of cycle. Where to get this CAP
MAke sure that it is not a leak from a loose joint of the hose clamp or the leak from the drain pump/valve. if you think that the drain end cap is missing this can be plugged using a similar rubber plug. If not try the Whirlpool dealer- service - for the correct part.
Apr 21, 2011 | Dishwashers
There is still water on the dishes and in the dishwasher after the heated drying cycle. Not a lot but enough to wet the kitchen floor. What can we do?
check the kitchen drain is clear - looks like the drain cycle is not working efficiently.
Also make sure the filters at the base of dishwasher are clear.
Try a short cycle (like rinse only) and see if water drains at the end. If problem is occuring only during the normal wash cycle, then drying fan may be the problem.
Jan 08, 2011 | Whirlpool DU1055XTS Built-in Dishwasher
Dishwasher runs for appx 14 min & stops washing half way thru wash cycle. Timer contunies to run. No drain pump out (nothing). Let dishwasher set idle for appx 1 hour and it will re-set. Set timer...
This sounds like something is stuck in the drain pump. You can remove the inner cover to look for obstructions. You have a dual purpose motor it does the both circulating and draining. The blockage is causing it to overheat and trip the thermal protector. You can remove the drain assembly from underneath if you don't find anything from above. There is a video at www.appliancehelponline.com/servicemanual.html that walks you thru most of this. It is a different model but pretty close.If you find no obstructions the motor may be failing.
Apr 08, 2010 | Whirlpool DU840CWD Dishwasher
Whirlpool dishmachine drain problem
you first need to check the drain hose .The hose needs to form a loop higher than the drain pipe that it is attached to.If their is no loop than the water can come back into the dishwasher
Feb 02, 2009 | Home
Did not drain after wash
My Whirlpool dishwasher model no. DU960PWKQ1 will not drain after wash. Dismantled impeller/strainer and there were no clogs.Drainline is clear.
I think motor is reversible, so there is no drain valve? HELP ME PLEASE.
Jan 13, 2008 | Whirlpool DU960PW Dishwasher
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
