Question about RCA P60920BL 60" Rear Projection Television
RCA P60101EB 60" rear screen
  • 133 Answers
SOURCE: Rear Projection TV P52770EB
You could have a few problems . If the front display light flashes only it could be you need a new deflection module . Also the HV block may be bad with it . If you have no front display light when you turn it on it could be the above problem or the signal board could be bad . The signal board would cost the most to get repaired due to it costs more. You would need a meter to check certain testing points to confirm which module is bad . Or call around to see who has the cheapest rate on an estimate to check out your tv. deflection board and hv block est $250 to $300. Signal board $300 to $350. Maybe more if you had a service call if you could not take it to a repair shop. Good luck
Posted on Mar 04, 2008
SOURCE: my 60 inch rca rear projection tv will not come on
i have had same problem repairman states splitter is bad has an upgrade for $350.00 the next time repaior man could not find part,,advised he would have to replace entire box this cost $275.00 and also states thiis would be a later model than my original box,the picture is great never been this good.note when i say box i ment the box inside tv with all the electronice and projector
Posted on Mar 27, 2009
SOURCE: rca rear projection tv has sound but no picture. clicking noise coming from the back.
replace the lamp.
Posted on Apr 15, 2009
  • 47 Answers
SOURCE: 52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Posted on Sep 19, 2009
  • 139 Answers
SOURCE: 60 INC RCA PROJECTION CURVED PIC. TOP BOTTOM
This problem is caused by a faulty Convergence amp. This amp keeps all three colors aligned together and square on the screen. It could also be the power supply section that supplies power to this amp.
A local TV shop should be able to repair this for you for about $350
Posted on Jan 06, 2010
Testimonial: "VARY HELPFULL THANK YOU"
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Tv wont work
does the power indicator blink? If so how many blinks? also do you hear any sounds when you press power?
Aug 09, 2008 | RCA P52926 52" Rear Projection Television
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
Tv repair
usuallt that model can have issues with the flyback going out without warning. Go to this link and leave them an email indicating your model number and symptom they will be able to help you out they have alot of experience with RCA products
http://servicemanuals.vstore.ca/
May 07, 2008 | RCA D61W20 61" Rear Projection Television
RCA model P52927
Look, take out back cover and on the bottom left and right side you will see screw (2 or 4), take out it,Disconnect 2 plugs wire from chasis, pull out the box and you will have space for clean your screen.( You will take out all box with main chasis, convergence chasis )
Apr 22, 2008 | RCA P52926 52" Rear Projection Television
TV fried from power surge
What is the chassis number? It should be located on the rear of the set. Have to have the chassis number before I can help
Mar 03, 2008 | RCA P60920BL 60" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
