Question about Casio Watches
How to remove links from a metal casio S1108DB watch band. This band is on a Casio man's MTG900DA-8V Watch.
3 Suggested Answers
  • 101 Answers
SOURCE: I want to shorten my watch band on my new Casio
In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
Posted on Oct 18, 2010
SOURCE: I need to shorten the metal link watch band of my
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Posted on Jan 02, 2010
I need to know where the little springs go on a casio mtg-900 2638
See the video at http://www.youtube.com/watch?v=R6JbrVDqR7w. It will show you the entire process, including springs, and critical concerns.
Apr 30, 2011 | Casio G-Shock MTG900DA-8V Wrist Watch
I have a Casio MTG-900DA-8V watch. I cannot hear the alarm when it goes off. I'm sure the alarm is working because I can see the icon pulsating at the time of the alarm. Can this be fixed? Thank you.
It might be that there is a "mute" command in the settings that needs to be turned off.
If you haven't got any instructions, you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 10, 2011 | Casio G-Shock MTG900DA-8V Wrist Watch
I need to know how to set time and date i lost the instructions. Can you help?
You can get instructions from the Casio web site.
watches;
Accept terms
Feb 27, 2011 | Casio G-Shock MTG900DA-8V Wrist Watch
My Casio watch band has split apart where the rubber part holds the main pin to the steel watch band making the band unable to be repaired. I would like to find a replacement watch band.Can you help me?
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Oct 26, 2010 | Casio G-Shock MTG900DA-8V Wrist Watch
HOW TO CHANGE TIME ON CASIO GSHOCK 900
Select "support" and the "manuals", watches;
Accept terms
Mar 15, 2010 | Casio G-Shock MTG900DA-8V Wrist Watch
If i buy from usa will it still callibrate to
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
NO it is collaborated from Colorado.
Hope this tip helps.
R/
David
Dec 06, 2009 | Casio Atomic-Solar MTG900 Watch
Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
May 24, 2009 | Casio G-Shock MTG900DA-8V Wrist Watch
Watches Logo
342 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
