Question about Frigidaire GLER642A Electric Dryer
The heating element is good but doesn't heat up, I put a meter on the power coming in and both legs of the 220 coming in are good, so is my problem the timer and how do I check?
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Posted on May 26, 2011
Why isn't the dryer heating up? How old is this dryer, and should I call a repair person or buy a new dryer?
I don't go out ant Google peoples machines her. You need to do it, but no heat almost always means a hilimit switch or the element. Both are fairly easy to fix. You need an ohm meter or voltage meter and a battery to check a hi limit switch, bit just your eyes to check an element. Gonna have to pull the back panel off either way. Really not hard. If you see that the element is broken, replace it. If element is not broken, test the limit switches by using an ohm meter, or test it using a battery and low voltage light tester and battery to see if the circuit is open or closed. Closed means the switch is bad and just MAYBE another prob but not likely.
Dec 12, 2015 | Dryers
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
My ASKO T781 butterfly dryer is heating up but not tumbling/spinning
If yourdryer is not starting then it is your motor. To determine this there is a trick you can try. First, put a piece a tape over the safetyswitch on the dryer. Take one hand andspin your drum of your dryer as your press the start button. If it takes off, then there is a bad spot onthe motor. Another thing is to try checkto see if you are getting 220 Volts to you outlet by taking a volt meter set at250 volts. Take the red leg of the volt meterto the one side and the black leg to the other side. If the volt reader reads 220 then you aregetting the proper voltage. Finally, ifyou are getting 220 volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is forthe motor and leg is for the element. Ifyou are getting 220 volts then it is more than likely you have bad motor.
May 15, 2011 | Asko Dryers
Asko t701 dryer won't start
If yourdryer is not starting then it is your motor. To determine this there is a trick you can try. First, put a piece a tape over the safetyswitch on the dryer. Take one hand andspin your drum of your dryer as your press the start button. If it takes off, then there is a bad spot onthe motor. Another thing is to try checkto see if you are getting 220 Volts to you outlet by taking a volt meter set at250 volts. Take the red leg of the voltmeter to the one side and the black leg to the other side. If the volt reader reads 220 then you aregetting the proper voltage. Finally, ifyou are getting 220 volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is forthe motor and leg is for the element.
May 11, 2011 | Asko T701 Electric Dryer
What to Do If a Dryer Won't Heat? Brand name Inglis, It's only 2yrs old, While I'm using stop for a while then when I start again the timer is done my clothes is not dry & it's cold. We...
If yourdryer is not heating, check your dryer's venting. First thing to check is to see if you aregetting air flow to the outside through your vent hood. Next, check your voltage to see if you aregetting 220 volts to your outlet. Youcan do this by taking a volt meter set at 250 volts. Take the red leg of the volt meter to the oneside and the black leg to the other side. If the volt reader reads 220 then you are getting the propervoltage. Finally, if you are getting 220volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is for the motor and leg is for theelement. If you are getting 220 volt thenit is your heating elements that are bad.
May 11, 2011 | Dryers
I AM GETTING ELECTRICITY TO THE 220 PLUG AND THROUGH THE 220 PLUG WIRE TO THE STOVE JUNCTION BOX. THE STOVE TOP AND OVEN HEATING ELEMENTS ARE NOT HEATING UP BUT THE INDICATOR LIGHTS FOR BOTH ELEMENTS SHOW...
The indicator lights operate on 120 volts whereas the elements operate on 220 volts.
Using an electrical test meter go between the two hot legs and see if you are getting 220 volts. If not you have an open or non completed circuit.
Do not test from one leg to ground as you will probably read 120 volts for each leg. By reading across both legs you should get 220 volts.
May 03, 2011 | Microwave Ovens
Dryer will not heat up? What should I check first?
Without knowing the make of the dryer, I will take you through a generic checklist.
1. Check the power to the outlet. Most dryers are on a 220 volt circuit. If one leg of the circuit is not powered, it can cause the heater element not to work while the rest of the dryer is powered. If you don't have a meter to check the circuit, try turning the circuit breaker off then back on. I have seen the circuit breaker not trip completely and look set when one leg was off.
2. Depending on whether you have a meter to check continuity, you can check the leads on the heating element to make that the element is not broken. A broken heating element will not heat.
3. Most dryers have a thermal fuse (or two) on the vent cowling that leads to the vent hose. If it (or either) is blown, the dryer will not heat up. Again, you need a continuity meter to check it.
Those are pretty much the basics I can give without having much more information to go on.
Hope this helps
Jun 13, 2010 | KitchenAid KGYS850LT Gas Dryer
Frigidaire GLER642A Electric Dryer Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
