Question about GE Spacemaker JVM1640SJ Microwave Oven
You keep putting in the wrong model number for my micro. it is JVM1840WD001 need info about replacing control panel
  • GE Master
  • 9,085 Answers
On this model, the most common problems are trouble with the cooktop lights and/or fan, and a buzz or hum which may be accompanied by failure of some other functions to work.
We repair these boards for $39.95 in most cases.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or you can order a new control board (smart board) part number
WB27X10436 for $234.26 from the Pros here, our favorite supplier.
You can find handy exploded views and order parts by model number
here.
Posted on May 26, 2011
Microwave quit working, timer, number buttons timer, all functions on micro side of control panel quit working , timer numbers start etc.
Check to see if the fuse went. If negative then something is wrong with the electronic pad for the unit.
Nov 25, 2015 | Microwave Ovens
How do i fix the se on a micro wave
"SE" means you have a defective membrane keypad.
With your full model number, I could have given you detailed instructions and parts numbers.
But without that, I'll have to just be generic.
If your model's membrane keypad is available as a separate part, that's usually the cheapest but most involved way to fix it.
Here is a handy guide with pictures showing you what's typically involved.
If it's not available separately, then you can replace either the control panel frame assembly, which comes with a new keypad on it, or the entire control box / controller assembly.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 16, 2013 | Maytag Microwave Ovens
Micro does not heat
Without your model number, I'd have to assume that it's a Whirlpool -made Kenmore. If so, then F6 means the cook relay is failing on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 23, 2010 | Kenmore 62702 Microwave Oven
Kenmore Elite micro/convect model 64289. Convect not heating...F1 error
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 18, 2010 | Kenmore 63672 Convection/Microwave Oven
Re: Oyster Micro-wave 1000 watts-LED Panel not working correctly.
you probably have to replace the keypad control, or you could try checking the connections to the keypad by taking the cabinet and checking the connections to see if they're loose.
Sep 30, 2009 | Microwave Ovens
I have a microwave unit separate from my oven unit. After I replaced the microwave plate with a dinner plate (because it broke) the following happened after a few weeks: The micro wave suddenly did not...
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 30, 2008 | Microwave Ovens
Micro beeps 3 times with "F3" flashing on LCD screen. Nothing works.
If it's a GE model, F3 will mean a shorted key panel.
(If it's not a GE, please reply back with your brand and model number so we can help you).
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
BUT If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
prototech@usa.net
Jun 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave panasonic model nn 6358 about 10 years old
In most cases, you press Clock, enter the numbers for the time, then press Clock again, or possibly press Start.
Sometimes you have to press Clock, Clear numbers, then Clock or Start.
Or Clear, Clock, numbers, then Clock or Start.
In some older models, they had a very small mechanical clock button located at the top right corner of the controller near the display window. If yours has that, press it, then the numbers, then that button again or Start.
If this doesn't do it for you, could you post a clear photo of your control panel?
Mar 21, 2008 | Microwave Ovens
Whirlpool Microwave
Sounds like the mounting tabs have broken on the plastic control panel frame. You'll probably have to order both the control panel frame and the membrane keypad since they are attached. You can't peel your keypad off the frame and put it on the new frame. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Search for model number as MT9100SFB0 Another option if you prefer not to replace the control panel frame is to glue it in place, probably from the inside, but you need to be sure the mating surfaces are squeaky clean and dry.
Sep 08, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
144 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
