Question about HP Compaq Presario V2000 Notebook
Laptop compaq v2000
A blue screen appear on my laptop saying: " a problem has been detected and windows has been shut down to prevent damage to your computer. if this is first time you've seen this stop error screen restart your computer. if this screen appears again, follow these steps:  disable or uninstall any anti-virus, disk fragmentation, etc.... i' ve been doing this steps like restart but how can i restart. when i turn off it will appear the screen like: safe mode, safe mode with networking, normally windows etc..... i try everything but it comes back to the original problem. i let it cool down a bit but still the same. please help me
  • Anonymous Sep 03, 2008
    I got the same problem with the blue screen. I already do the test and it was failed, got something show the number #...07. What is that? and how much the cost if i want to replace it?
  • Anonymous Sep 07, 2008
    Same issue here too. Happened after I installed the latest windows update I think. Displays the windows boot options but shows the bsod and reboots to the same screen. Used the windows repair disk that came with the computer, and got it back up and running. Had to run chkdsk /r to repair any damaged files after getting the dos prompt. However, no internet, network, printers, only have access to data (which I am now backing up). Everytime I try to install printer drivers it says the RPC service is not running. Kicked off a spyware check just now and will see what happens. If that does not fix it, will back up data and format the drive and reinstall windows.
  • 4 Answers
Your windows install is screwed up. i'd dig up your Windows XP CDand pop that in and do a repair install. if it still doesnt work then i'd enter the bios setup (hit F10 on compaq boot screen) and look in there for "Hard Drive Test" and run that. be aware it will take 70 mins on a 60GB hard drive, and longer for a bigger drive. if the hard drive passes the test then you may want to boot up the XP cd and do a fresh install, opting to format the drive. be aware that formatting WILL delete anything and everything on the laptop.
if the hard drive fails the test, then obviously you need to get a replacement drive and reinstall Windows on that. if the hard drive failed, any data on it is most defenetly toast.
Posted on Aug 20, 2008
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
My Compaq Presario V3000 has a problem with the wireless on it. Whenever the wireless side-switch is turned on before I turn on my laptop, before it shows the login screen a blue-screen message shows...
you should reinstall the wireless drivers on your laptop go to the hp support site and type in the model number (it can be found on the white service tag under the laptop)
Jun 14, 2011 | Computers & Internet
I get a bluescreen on startup that says a problem has been detected and windows has been shut down to prevent damage to my computer.PAGE_FAULT_IN_NONPAGED_AREA
Most blue screens are due to a memory failure...try to remove the memory cards and just replace one at a time to see if you have a bad module or slot.
Jan 29, 2010 | HP Compaq Presario C306US Notebook
Laptop starts dumping memory
Please run a system restore to factory settings.
May 14, 2009 | HP Compaq nx7010 Notebook
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Compaq Presario V2000 boot problem
Bios is not on an hard drive, is on a memory chipinside computer. Your main problem is not with Bios, but with system.
On many Compaq you can start the recovery tool by pressing f10 or f11 on startup. The system recovery tool it is located on hard disk, if it does not start it had been deleted or is damaged.
In your case Windows is corrupted, that is the reason why it is freezing , and then giving the blue error screen.
You need to get a Windows setup disk and reintall Windows. If you install windows from a generic setup disk you will need to install drivers after installing.
Drivers can be downloaded from HP website.
Another solution is calling the phone number listed on the user manual to contact HP. you can buy from them an original recovery CD, in this case you won't need drivers.
Otherwise you can ask a quote to a local repair shop for a system reinstall, I think it is about $80.
Sep 02, 2008 | HP Compaq Presario V2000 Notebook
Laptop compaq v2000
This is called the Blue Screen of Death (BSoD), as scary as the name sounds if your laptop isn't ancient you more than likely can save it. depending what you were doing on your pc last, installing a game or whatever, start it in 'safe mode'. it should start up just like a normal computer but with a few changes like anti virus disabled. From here you can unistall whatever you were last doing on the computer, clean it up and try get her running again, the usual stuff, try defrag the computer, right click the drive in my computer>tools>defrag now, theres also other options in there like clean up and error checking both will help. Try and save it yourself, if all this fails your computer fixing person will probly have to wipe your hard drive, in which you will loose all your data and start a fresh laptop.
It would also help to know what you last did on it, on the net? downloading stuff? installing something?
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Jul 10, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario V2000 Notebook Logo
530 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
