Have 3rd HK Avr 254 receiver (first two killed under warranty by t-storms) with most current firmware , dsp version 1.2.9. Have never had a problem connecting my 2 year old PS3 60GB to the receiver via hdmi but this new replacement seems not to work connected via hdmi. TV display returns 'no signal' and after power cycling says ' connection' prior to no signal? PS3 works fine when connected direct to TV via HDMI? HK CS Says problem has to lie with PS3 video setup which has not been changed since last receiver swap? I have tried all hdmi cable / port combinations and also have a cable box conected to the receiver via hdmi (all ports / cables tried) that works fine? Any insight into what I could try other than a system reset (which is nect on my list) would be appreciated/ Mike
  • 3 Answers
SOURCE: Best speakers for HK AVR 135
klipsch, klipsch, klipsch
Posted on Feb 06, 2008
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
  • 3 Answers
SOURCE: Harmon AVR 254 No Video, No Sound.
Mine was replaced by HK under warranty with a brand new one with the latest firmware. I had to wait about 2 months though to get a new one as opposed to a refurbished one. You have to demand it. Otherwise you get the refurb. My new one hasn't exhibited any issues and everything seems to work better than before (PS3 menu "clicks" all seem to work now and I don't get the pink or green flashes between sources I used to get). So a replacement was the fix for mine..... :(
Posted on Sep 08, 2009
  • 1114 Answers
SOURCE: getting picture lines across tv that keep
You will need to run HDMI directly from TV to Cable Box. Then run an optical or digital coaxial from your cable box to your receiver. The version of HDMI in your receiver is 1.1 or 1.2 and will not pass signal correctly. The recording industry has placed many roadblocks in front of HDMI to keep us from recording.... Go figure... That's the fix though. Hope this helps
Posted on Dec 20, 2009
  • 1039 Answers
SOURCE: i need 2 find a remote 4 hk avr 254 i need part
You can buy it directly from Harma Kardon website.
Posted on Mar 28, 2010
Harman kardon avr 254
You can check all your speaker wires for shorts, as well as try the reset to factory defaults procedure found in your owner's manual, but I doubt this will resolve your issue. If you require more assistance, or would like to inquire about repairing your HK, please visit my website at, and contact me there. BTW, I worked for Harman as technical support for all Harman, JBL and Infinity products. Thank you.
Mar 23, 2014 | Harman Multimedia AVR-254
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
I have the Harman Kardon AVR 254. Just recently it stopped responding. It will cut on and the volume dial will respond but none of the front panel buttons will. Any suggestions on a fix?
There should be two fuses on the secondary board of the main power transformer. They don't look like regular fuses - they are small round can fuses. These are probably open. HK under-valued these fuses originally, and they need to be replaced with 3.15 amp.
Jan 17, 2013 | Harmon Kardon Harman Kardon Avr 254 7.1...
Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Jun 27, 2009 | Harman Kardon AVR 235 Receiver
Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Apr 01, 2009 | Harman Multimedia AVR 247 7.1 Channels...
The reason your receiver is causing you issues is cause of a 2 time Delay fuse's on the transformer board all you have to do is to by pass them.
Check the connector on the top front of the HDMI board. at the bottom of the connector it tells you the voltage of each wire the middle one is GND. should read 1.8v and 5.6v if the 5.6v line is dead. you key's in the front panel and sometimes video and audio as well.. will also stop working. all you have to do is to by pass them.
I will be posting a video later today on how to fix this issue. Regards,
Search for AVR 254/354 fix
Mar 25, 2009 | Harman Multimedia AVR-254
Channel out.
The DSP board is defective. You need help from a HK tech
Mar 18, 2008 | Harman Kardon AVR 130 Receiver
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 02, 2007 | Harman Kardon AVR 325 Receiver
37 people viewed this question
