Question about DSC Lc-151 Outdoor Pir Motion Detector Lc151 Sensor
Hi, I just got intall an LC-151 sensor by my Alarm company, the setup the sensor and made some test but in the night the alarm goes on so i shut it down and next day i could turn on the alarm. Probably this sensor was not setup correctly but I wonder where can get some lectures to know more about it? Saludos
My 2000 Chrysler LHS alarm goes off hours after locking doors either manually or with remote. Unlocking the driver or passenger door will shut it off but how do I correct this problem?
I do not know how to "fix" the problem to make it right, but you can disable the alarm through the relay box or fuse box. You'll lose the alarm, but can lock the car. Several may be labeled "Alarm and... try to find one that is the alarm alone or something significant, if possible. Not an answer, just an Idea.
Nov 01, 2014 | 2000 Chrysler LHS
Door open sensor trips and alarm sounds
It's either the sensor itself or the wiring from the sensor to wherever it goes. I would start by swapping the two rear sensors and see if the fault moves to the other side. If not it's the wiring which you will need to trace and check all connectors involved.
May 08, 2014 | Ford Escape Cars & Trucks
Alarm goes off in the middle of the night, it Will shut off with the fob but goes off again in a few minutes, what to d?
There may be a fault in your main car battery being detected by the alarm as an unexpected current flow. Another possibility is your alarm may have a vibration sensor set to point which is too sensitive.Possible short on your wiring or fault on the circuit board in the alarm itself. It could be something as daft as a fly or spider in your car activating any ultrasonic sensors you have. Unfortunately the lisyt is endless with alarms.
Dec 12, 2013 | Mitsubishi Cars & Trucks
2006 buick alarm can not be shut off.....
After the key is put into what? The OEM alarm is armed and disarmed through the driver's door key cylinder. Insert the key into the key hole of the driver's door, turn to unlock, this disarms the factory alarm. Turn to lock, this arms the factory alarm. Now, if you have an aftermarket alarm this procedure does not apply.
Oct 07, 2012 | 1998-2002 Park Avenue Door Lock & Alarm...
OUR ZILLIONZ ATM SAVINGS BANK HAS AN ALARM THAT KEEPS GOING OFF EVERY NIGHT AT 12:01! IT IS DRIVING US CRAZY...HOW DO WE MAKE IT STOP...THERE IS NOTHING IN THE INSTRUCTIONS ABOUT AN ALARM AND WE DID NOT...
It does have an alarm. Press and hold the third button for approximately 10 seconds. This will enter the alarm function, at that point press one of the upper buttons to turn alarm symbol off...
Jan 07, 2011 | Sears Zillionz ATM Savings Bank
My maxima 2001 alarm goes off for no reason - how to stop it
fluctuation in voltage on the car will do this also a weak remote battery will also. If this is aftermarket alarm set the shock sensor a litle higher. BUT if this is at night when the vehicle is alone I wouldnt shut it off because someone may be tripping the alarm so you will shut it off and then they can get into your car or possibly steal it which is an old thieves trick.
Oct 04, 2009 | 2001 Nissan Maxima
Alarm Malfunctioning - 2004 Sable
Have your battery checked for shorts. Mine was defective on a new Lincoln. Same problem. Even sat in it at 18 degrees one night to appease neighbors whom my alarm woke up.
Check connections at every possible point if the battery tests good.
Get up 30 minutes before alarm usually goes off and see if neighbor has loud car or slams his car door. Motion sensors can set it off too.
Aug 17, 2009 | 1998 Mercury Sable
2002 ford explorer-alarm goes off in the middle of the night...no one around
Spray WD40 into all door latches, then shut and reopen doors till light and dinging stops.
Aug 03, 2008 | 2002 Ford Explorer
Viper auto alarm
Change the battery in the keyfob..
Jan 03, 2008 | Viper RCVGC022 Remote Control
DSC Lc-151 Outdoor Pir Motion Detector Lc151 Sensor Logo
37 people viewed this question
Top DSC Home Security Experts
don1956
Level 1 Expert
L Pfaff
L Pfaff
Jerry Kramer
Jerry Kramer
Are you a DSC Home Security Expert? Answer questions, earn points and help others
