Question about HP Pavilion a350n PC Desktop
Storm knocked power off late yesterday afternoon....back on this morning. PC won't power up....small green light on back flashing. Modem, router, etc. all back up and running, but PC won't turn on. Help!
  • 367 Answers
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
Posted on May 25, 2011
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
2000 gmc safari parked in the rain won't start
Did you take the distributor cap off and see if it has moisture inside ?
Apr 14, 2013 | 2000 GMC Safari
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Mazda 626 (1994) Random intermittant stalling
The first thing you need done here is to have the dealer or a shop scan the ECM (computer) for fault codes, this could be just a defective electronic engine control sensor like a crankshaft sensor or a defective ICM (ignition module). So before you do anything else have the scan done with the special scan tool required.
Jun 20, 2012 | 1994 Mazda 626
My router flashes DSL, no light on the internet, ethernet and wireless flash together, and power light on. no wired or wireless internet. solution? the afternoon it happened, a lightning storm came thru...
Hey danielbartle,
Since a lighting storm came through there is a good chance your router has been fried.
I would first direct connect via your modem to see if you get a internet connection and rule out your modem as a problem. If that doesn't work I would try another ethernet cord to rule out your cord is a problem. If you get no connection directly through your modem, I would contact your ISP with your problem.
If you get a connection I would then reset the router by unplugging and waiting 30 seconds and plugging it back in.
If still nto succesful I would reset your router to defualt settings by a small button you will find on back.
If none of these work I would head to your local computer shop and pick up a new router.
Thanks for using Fixya!
Jul 22, 2010 | 2wire (1000-400108-001) Router
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
HP Pavilion a350n PC Desktop Logo
317 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
