Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV
HOW DOI RE-PROGRAM TO GET CABLE CHANNELS? NOW I GET ANTENNA CHANNELS
  • 10,594 Answers
What is model number of tv?
Is it connected with cable box or cable from wall?
These info will help to provide you required info.
Thanks.
Posted on May 25, 2011
How to use an antenna box for more channels
Once the antenna is mounted and connected to the TV then you can go into setup menu and do a channel search. You will be prompted to set it up as CABLE or AIR/ANTENNA. Select ANTENNA and it will program all available channels for you.
Apr 19, 2016 | Televison & Video
Re: tv unable to program channels
Hm..
So you want to connect your receiver thing to your tv ?
or your cable ?
Well if the antenna cable is hooked up, you should be able to simply run it up behind your tv and put it on the antenna plug.
The reveiver should attach to your tv with a cable provided.
Dec 27, 2007 | Televison & Video
How to program channels
go into settings and then rescan for channels
May 07, 2015 | Televison & Video
On an orion tv, how can i get channels after 13??
In the menu, find antenna/cable. Locate cable and program from there.
Dec 20, 2014 | Orion1934 19" TV
Sanyo drw-500 dvd recorder will not recognize channels from antenna in setup
Have you set the Sanyo to "antenna" or to "cable" ?
If you've tried one setting, try the other.
Apr 16, 2014 | Sanyo DRW-500 DVD Recorder
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
No channels after auto-program runs
Something isn't right. Try a wire as an antenna to the Panasonic, set it for air/antenna and see if it finds anything. You should be able to pick up at least a couple of stations even with a wire....
Mar 22, 2010 | Panasonic Televison & Video
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Can not program my cable channels
move your antenna around to get maximum signals to be able to scan.
Jul 02, 2008 | Real Digital RD2200 22 in. HDTV-Ready LCD...
Tv won't get channels
We have the owners manual in case you misplaced yours . All ya gotta doi to get it is to click on the zenith B32A34Z model # At the top of this page and scroll down to the manual. Now according to the manual in the menu there is an antenns /cable setting and its in the EZ progrom mode. look at the manual as I dont remeber 100% but its there. It sounds like you or someone switched it when they were in the menu. Good Luck
May 11, 2006 | Zenith B32A34Z 32" TV
Open Questions:
Insignia 19 in. Widescreen Flat-Panel LCD HDTV Logo
20 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
