Question about Homelite Mighty Lite Lawn Trimmer
Weed trimmer wont start, spark plug has spark starting fluid down the cylinder head and re installed plug still doesnt sputter at all. also sprayed starting fluid into carb. no sputter. again it does have spark and did try another plug. compression test was at 60. what could the problem be? timing?
    President:
  • Homelite Master
  • 1,545 Answers
The timinmg is preset by the permanent keyed slot built into the inside of the flywheel where it mates with the crankshaft. If the key was broken off, you would get No spark because of the nature of the magneto ignition. Your compression is actually pretty low for a 2 stroke. It should run higher like around 90+. Try this. With plug removed, cover plug hole with thumb and give the pull start a real strong pull. It should push your thumb off of the hole. If it doesn't the compression is too low for the engine to run. Scored piston walls, or cylinder walls could be the problem. Again 60PSI is really low. I would remove the jug and check for piston scoring and cylinder scoring. The engine can be easily rebuilt (but not real cost effective).
Posted on May 25, 2011
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Troybuilt tb80ec wont start
If you didn't over winter the engine properly it could be several things. Start with replacing the fuel filter. If it still won't start... time to put in a carburator kit. Next time make sure you run your weed eater dry and spray some wd-40 or the like into the spark plug hole.
Jun 02, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
I left my gas Ryobi Line Trimmer out in the rain on accident and now it won't start. I pulled the spark plug out and it looked fouled so I replaced it. It's still not starting with the new spark plug. I...
Try removing the fuel, remove the spark plug and give a few pulls to remove starter fluid from the cylinder, once completed attach your spark plug and check spark, reinstall plug, add fresf fuel to the tank and try staring with normal cold start procedure. Does it have good compression?
Sep 27, 2013 | Ryobi Garden
I have a weed eater trimmer that wont start. ben sitting for a couple years and i replaced the fuel lines andcleaned the carb. still nothing, what do i do?
Try cleaning the spark plug, make sure it sparks. Put some fresh gasoline in the tank, check start stop switch.
A easy way to check whether the problem is related to carb or not is:
remove the spark plug put some fresh gasoline in the cylinder, put the spark plug back
pull the starter a few times if it starts for a few seconds it means is related to carb.
Be carefully when handling gasoline.
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
Having a problem starting my Shindaiwa T22 Weed Eater.
take the spark plug out and pull the engine over with the spark plug in the wire and ground the plug to the trimmer and see if it sparks. if not flip the switch the other way and see if it sparks then you shall know.
May 02, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Trimmer model: Sears 358.796121: no start
Could be a faulty kill switch not allowing it to start, sounds like you covered all the things I would check.
Jul 09, 2009 | Craftsman 25cc Gas Line Trimmer
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
What coul be keeping my 1986 honda civic from starting? The plugs all spark, the fuel pump gives gas to the carb, Ive changed all plugs cap and rotor and have tried spraying starter fluid directly into...
It cranks really good sputters a little and makes some loud pops but it will not turn over? FYI:Cranking and turning over are the same thing. When was the last time it ran. The gas could be bad. Did you get new plug wires as well. Try testing the distributor, remove a spark plug, plug it back into the wire, and touch the threads to ground and crank the engine. It should spark. Keep your fingers away, that's high voltage. Remove all spark plugs, spray some starting fluid in each cylinder, then crank the engine with the plugs out. This will clean any debris from the cylinders. Engines need backpressure to run properly, a major exhaust leak hence the popping, could cause it to not run. If you can get it started try to keep it going, full throttle, keep in the starting fluid, it could just need to get warm. I used to have one of them and they don't like it when they're cold.
Mar 23, 2009 | 1986 Honda Civic
Homelite Mighty Lite Lawn Trimmer  Logo
296 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
