Question about Bosch Classixx WFL 2462 Front Load Washer
Bosch WFL2462GB goes back from active to ready seconds after it starts
2 Suggested Answers
textonor
  • 130 Answers
SOURCE: Bosch Maxx lights on, hit Start as normal but nothing happens. After a while it goes back from Active to Ready flashing.
First question is does the display light up? If so then does the door lock? If the door is locking then the fuse for the washer that is on the back of the dryer hasn't blown. However if door won't lock, then check the fuse to see if it is open. This is a 208/240 volt washer and the display is the only part that doesn't need 208/240 volts. If fuse if find, then check the water screens in the fill hoses and clean them. This may be more of a control unit issue having failed, Hard to tell without knowing age of unit. Hope this helps
Posted on Jan 28, 2008
Bosch wae2446bgb/10 With. F21 fault code. Manual said motor fault so brushes have been replaced. Phoned Bosch and said to hold the start button for seven seconds to reset the machine, but I dosnt seem...
Have you unplugged it, then plugged it back in? Also, try holding the start button as suggested, only do so until (hopefully) it reacts to doing so. If not, unplug and let sit for 30-60 seconds, then plug in and power up. If it still persists, contact Bosch again and let them know its still doing it, and what you have tried.
Apr 06, 2013 | Washing Machines
At start up the machine goes directly to CLEAN after about 2 minutes
Step 1:
Have the same problem with my dishwasher Bosch SHE4AM12UC. Bosch authorized repaiman has been out 3 times and changed main power board module 3 times, on the manufactures recommendation--he's given up fixing it and Bosch won't help either, just tells me to call somebody else on their list and get a second opinion (of course at my expense for labor). Anyway, steps are listed below that have worked for me to keep it limping along until I can get this figured out hoe to fix it.
Step 2:
When you start machine listen for drain pump to start up. Open door and you will hear sucking noise if it is running drain pump.
Step 3:
While you have door open, hold in start button and close door (this may take several times doing this) . Listen for the water to start to fill and wash pump will start (you will hear water spraying around from was arms). Machine will start and run normal cycle once this happens. If you don't hear this within a couple of seconds of procedure above, repeat the sequence until it works. Remember i said it may take 2-3 times to make it go.
Step 4:
Hope this helps. I'll keep trying to figure this out and come up with a solution. Forget trying to get anything done from Bosch or their "authorized" repair people as neither of them have a clue on how to solve the problem.
Jan 27, 2013 | Bosch Dishwashers
Bosch 1200 child lock activated haow doi e activate
press and hold the start button for five seconds the "feature" should disable.
Jan 03, 2011 | Bosch Washing Machines
Bosch classixx 6 1200 express is showing a key symbol in the LED - when I switch on the washing time goes back to 0 and the alert sounds and I cant start the wash I dont know how to switch the key...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Aug 19, 2010 | Bosch Washing Machines
Bosch classic 6 1400 express washing machine - key lock symbol illuminated on panel when machine turned on so machine will not start. No instruction manual so wondering how to turn the lock off? Many...
This is symbol shows that the child lock has been activated. This can only be turned on/off at the beginning or end of washing programme. To activate/de-activate this, just press and hold the Start/Pause button in for 5 seconds. The time settings will then re-appear and then you can proceed as normal
Oct 17, 2009 | Bosch Classixx WFL 2066 Front Load Washer
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Will not start
To start unplug the machine power cord for ten minutes or longer, this will drain power from the machine and reset the electronic controls.
If this does not fix the problem check the following:
Check that the water supply at the back are opened and taking water into the machine.
Check that the door latch sensor is not stuck, and that door is well closed that is a frequent problem.
Check the drain hose and the drain lines, ensure that there is no blockage in there.
If this still does not work, then the machine has a faulty part that must be replaced, and must be tested by a qualified technician.
Use the phone number listed on the owner manual if you need to contact the repair service.
Dec 01, 2008 | Washing Machines
Jan 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WFL 2462 Front Load Washer Logo
64 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
