Question about Samsung LN52A650A LCD TV
As I switch on my TV LCD Samsung (model LE37A656A1FXXC), some vertical coloured lines (semi-transparent though) appears in the left-center of the screen. After more than 30 mins they disappear and they come back from time to time. Unfortunately my warranty has expired. Someone says it's a problem with the T-CON Board. Could you help me find a new one or suggest me how to fix the problem? These are the numbers I've found on the board: 72.37T04.003-O-JC1 Rev. N.: 2007-08-23 Code.no: BN41-0944A Model: FROM Thanks in advance Stefano
5 Suggested Answers
SOURCE: Bad transformer on Inverter Board
for me I think I'm gonna try Decision One a certified Dell fixer upper. I looked at my inverter and there were no burns that I could see. My problem is different from Headstrongs come to find out. Dell w3201c is the model number, it has samsung on parts under the hood....
good luck
Posted on Jan 15, 2008
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
eagle338
  • 4889 Answers
SOURCE: a horizontal band of semi
I would suggest that you first check the status of the connectors that go from the main board and the T-con and those that go from the t-con to the display. More often than not this problem is caused by loose connectors or a malfunctioning T-con. If you can get me the model number of your set, I can get you a replacement.
Posted on Jan 06, 2011
How to fix blue line appearing on my tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 02, 2016 | LG 42LM6200 42 in. 3D LCD HD Cinema Smart...
My samsung tv has thin vertical lines of all colours on left and right of screen
Jun 11, 2016 | Samsung Electronics UN55EH6000 - 55in...
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
I have Samsung LA32C400 LCD TV. Recently, some vertical lines appear on the screen, then colour changes, and sometimes the pictures doesn't move.
i have tv samsung model samsung lcd tv model la32c400...when you open the power on. they have a raster but it is hung .up...and then we open again the power booton on pwer it is have only light display ...and also based side have small line ruster only 3cm....what cause this and problem the t-conn....has fixed already in lcd or disposable .....what is the solution on this parblem......some help.....plssss txt me 09991375154 thank u.....
Jun 12, 2012 | Samsung LE Televison & Video
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
2 vertical bars on tv screen
OPEN THE TV AND BLOW IT OUT ..THOSE BARS ARE THE EFFECT OF DUST INSIDE THE UNIT CLEAN OUT AS WELL AS YOU CAN AND THAT SHOULD FIX
YOUR PROBLEM
I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
Feb 06, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Samsung LN52A650A LCD TV Logo
281 people viewed this question
Jerry Greenberg
Jerry Greenberg
