Question about Compaq Presario Notebook
Tv as monitor
I have bought a cord to connect my laptop(compaq 6741us notebook) to my lcd tv but when i do the tv says i have no signal. what am i missing?
  • xalint1
    xalint1 May 11, 2010
    Are you using Xp or Vista more then likely it is that you haven't went under display properties and turned the second display on.I can help your further if you tell me your operating system.
    Problem Solver:
  • 4 Answers
On my laptop i press function+F7
Posted on Aug 16, 2008
I connected RGB from toshiba m45-s169 to tv. Had a signal but now cant get it back. Tried updating video driver. Help?
You can switch to an external monitor, TV or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Oct 23, 2012 | Toshiba Satellite M45-S169 Notebook
How do i get monitor output
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a lkeycombinations for the laptops :-HP and Compaq = Fn + F4
Mar 11, 2012 | HP Compaq nc6120 Notebook
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
I would like to hook up my compaq presario v2000 to an external monitor/tv What cord would I need and where would I plug it in?
Connect the monitor cable to the D-type connector on the laptop. Once the monitor is connected to the laptop. Hold down the Fn key on the keybaord and tap on the F8 key to toggle the display on the external monitor
There are three stages of the Fn+ F8 key
1, Exterenal only
2. Laptop + External screen
3. Laptop only.
Thanks for using Fixya
Proton
Sep 06, 2010 | Compaq Presario M2000 Notebook
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
CONNECTIING COMPAQ LAPTOP TO MY NEW 42"LG LCD TV
If the cable from the laptop is connected to the TV, you've selected the VGA input and see no signal, you probably haven't enabled the laptop's VGA output connector. Somewhere on the keyboard will be a function key with a little monitor screen on it. Hold down the F or Fn key and press the monitor key and it will switch on the external monitor connector. On some monitors, the first press shuts off the laptop screen when it turns on the external connector. If yours does that, press the key a second time to turn the laptop screen back on.
Feb 16, 2009 | HP Compaq nc6000 Notebook
LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Nov 05, 2008 | Apple MacBook Pro Laptop Computer with...
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Monitor problem
with the notebook on shine a light onto the screen and see if you can see anything, if you can then its you backlight that has gone out. if you can't see anything. it may be the power inverter
Aug 19, 2007 | Compaq Presario R3000Z Notebook
Compaq Presario Notebook Logo
52 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
