Question about H&B CA-5555 Car CD/ MP3 Player
I was given a H&B CA5555, without the main plug and connections do you know where i could get this??
I am looking for a connector as well of my brand new H&B 5555
Where did you find one ?
I appreciate your help
best regards
Posted on Sep 29, 2012
LG 42LN5400-UA.BUSYLHR back lights not working, sound working, flashlight test shows video working.
This is a common problem for LG 42LN5xxx & 47LN5xxx LED TVs, the problem is defective LED back lights strips, it has nothing to do with main power supply & the main board.
Aug 31, 2017 | LG Televison & Video
I have a Sharp 70" (LC-70LE632U) LED TV. When you turn it on, the front led is on, but no screen. After a few seconds, the front led starts 5 short and 2 longer blink and continue this way constantly.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
Nov 12, 2015 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
How do I plug mixer into pa speakers, monitors, instruments
Without knowing what make and model of the gear you're looking to connect, I can't give you a definitive answer. However, in general, if you have a powered PA mixer, meaning it has both a mixer section and a power amp section in a single box, the main speaker outputs will be on the rear panel of the box and marked as such. There will also be a jack for monitors, but some mixers have an amp for monitors, some just have an output for the monitor mix, but not an amp for them, and on some you can switch the main outputs to feed either a Left and a Right speaker, or a front mono speaker and a montior speaker. Instruments will go into the individual channel inputs.
Feb 08, 2015 | Music
What wire do I plug in for the subwoofer cause I I have read cables but there's 2 and I only have 1 connection for the sub on the back of the stereo
This subwoofer is probably powered directly from the amplifier and doesn't have an internal amp. The connections are probably the same type as for any other speakers. And, there are probably additional connections for the rest of the speakers. The connection on your amp is likely an RCA phono plug connector that sends low level signals to a powered subwoofer. To connect a passive subwoofer, one without a built-in amp, the main speaker outputs connect to the subwoofer and are then sent to the regular speakers connected to additional terminals on the subwoofer. You may need an owner's manual for the subwoofer to determine how it should be connected.
Aug 23, 2014 | Audio Players & Recorders
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
To convert the mains to 12volt supply to 12Volt suppl only
Well, the connector u can buy frm the particular company shop!! but for supply reazon, u hv to desgin plug for particular given vols..or just buy the normal adaptor or variable adopter
and get connect he 4 pin plug on that and enjoy!!
Nov 10, 2009 | Cars & Trucks
I don't know where to connect the main in & pre amp jacks??? to the EQ???
Not sure I understand your question, but I will try.
Your CD players, tape decks, etc., connect to the INPUTS on the preamp.
The LINE OUT on the PRE AMP connects to the LINE IN on the POWER AMP.
The pre-amp does some amplification and then it passes the signal along to the power amp, which will do the heavy lifting - driving the speakers.
The connection is usually through a shielded RCA plug cable. THere will be 2 cables from the Pre amp to the power amp - one for the left channel and one for the right channel.
The OUTPUT Of the power amp will connect to the speakers using large, stranded wire cables, sometimes with "banana" plugs that simply plug into the terminals on the power amp and the speaker.
Let me know if this gets your started.
Sep 28, 2009 | Audio Players & Recorders
Can only record sound not picture?
Make sure the Yellow RCA Cable is plugged into the Yellow port on the DVD recorder. People often try to plug these in without good lighting & will plug the White audio into the Yellow video ports. Also, check to make sure they are in the correct color ports at the TV as well.
Yellow = Video
White = Audio
Red = Audio
Another way to test the cable is to bring a smaller TV in next to the main TV. Use your RCA cables coming from the OUTPUT of your main TV that you want to record from & connect the other end of the cables to the INPUT of the smaller TV just to see if the cable is passing video. The cable could just be bad & you need to buy a new cable. Hope this helps.
Jul 17, 2009 | Panasonic DMRES15 DVD Recorder
I have my amp hooked up but it isnt getting any power can you tell me if i have a bad amp or if i need the speakers and sound for it to come on?
With all amplifiers for a car, you must have the main power connections B+ and ground connected, and then you must also have the remote turn on connected as well. This is the way the amp turns on. It comes from the radio and is usually the blue wire from the harness off the back of the radio. When the radio is turned on, the blue wire gets 12 volts sent to it so it can turn on an external device like an amplifier or the power antenna. Make sure you have this connected to the amp and that the radio is turned on. Then check the voltages at the power terminal of the amplifer. You will have the ground, the main B+ of 12 volts, and then the turn on voltage of 12 volts. If you have all of these, then you need to troubleshoot it more. It will turn on without the speakers connected, but I am not sure why you would want to connect it without the speakers. It will also turn on without the RCA cables connected for the audio input as well. But just to turn on the amplifier, all you need is those three things i mentioned. Let me know if you require any further help.
Jan 23, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
H&B CA-5555 Car CD/ MP3 Player Logo
160 people viewed this question
Top H&B Car Audio & Video Experts
xxxxxx xxx
Are you a H&B Car Audio and Video Expert? Answer questions, earn points and help others
