Question about Whirlpool Hardware & Accessories
The timer know on my whirlpool washer does not move. I have to go and turn the knob for the machine to get out of the wash cycle, the spin cycle and the rinse cycle.
    Scholar:
  • 122 Answers
If the knob does not move to the end of the wash, spin and rinse cycles (i.e. remains in one position) then the little drive motor that operates the timer/function rotary selector, has either lost power or is faulty.
If you have a multimeter (and know how to use it) then it's easy to determine if power is reaching the motor. If power is present, but no movement from the little motor, then you're probably looking at replacing the selector mechnism. If no power on the mechanism, then you will have to do some visual wire tracing (with power removed from the machine) to determine where the discontinuity is.
Bear in mind that once the washing machine is opened for measurement, you will be exposed to live mains power.
You are liable for your own safety. Take great care.
Posted on Jun 07, 2011
Whirlpool 6AWM8143 Front Load not starting spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM8143 Front Load Washer
Washer Doesnt Change Cycles
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd alto look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
My washer when it is in the wash cycle will stop at 1/2 way and not drain, spin or rinse. Could it be the timer? If I turn the knob manually I can get it to finish the cycle.
If you can manually turn the timer to spin and it drains and spins it is a bad timer.
If it drains only and does not spin it is a bad lid switch.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washer won't spin
    The first thing I would check is if your timer is advancing. Set it at th beginning of a wash cycle and let it go. See if the timer knob arrow advances. If it doesn't, your timer is bad.
    Oct 18, 2008 | Whirlpool LBR4121JQ Top Load Washer
    Whirlpool Ultimate Care II washer
    If it will perform all of the functions if you turn your timer knob manually, I would open the console and check for any loose connections, although from your description your timer motor has gone bad (only availible as the whole timer) It can be purchased from online from the manufacture or from a local parts store.
    Jun 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Hardware & Accessories Logo
    478 people viewed this question
    Top Whirlpool Hardware & Accessories Experts
    Joseph Mueller
    Joseph Mueller
    Are you a Whirlpool Hardware and Accessory Expert? Answer questions, earn points and help others
