Question about Fargo HDP5000 Thermal Printer
The message center say to check lam power and reboot required. How do I reboot the lam
  • Fargo Master
  • 4,338 Answers
Power unit off. Take Power cord off the printer.
Remove Lamination unit at the connector.
Check it for obstructions.
re-install the Lam unit.
Power up the unit.
Posted on May 25, 2011
I have a 1996 Ford Explorer that the floor messaging center quit working. Is there any suggestions on what might be wrong and or how to fix it?
Hi Leann, I'm glad to help!
There are only 2 possibilities with your problem. (1) Its possible you may not have power OR ground going to the message center. If you know someone that knows how to use a test light they could check power and ground at the message center. (2) The message center itself could be defective. If your friend finds power and ground at the message center then you'll need to replace the message center. If they do not find either power or ground at the message center. Then they'll need to check all the fuses to see which one is blown. Hope this helps and have an awesome day Leann.
Sep 17, 2013 | Cars & Trucks
Card Jam Error 112 & 245
please calibrate the Lam Film sensor.error 245 is lam sync error please check Lam power/connections and restart the Printer.
Oct 02, 2012 | Fargo HDP5000-LC ID Card Printer...
Sometimes does not send sms&need to reboot when it sticks
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Sep 01, 2012 | Sony Unlocked Ericsson W100i Spiro...
Iphone wont open one contacts messages
I would suggest rebooting your iphone.
Hold the power button (top right) do NOT release.
Now hold and (do not release). the home button (the center round button bottom of phone).
Hold both until screen goes blank... Wait for phone to reboot..and try again.
Jun 04, 2012 | Apple iPhone Apps
Message center not working
You either have a defective message center module or an electrical problem that is preventing the message canter from getting the proper power or ground to operate. Electrical and computer diagnostics are required to locate the cause of the problem.
May 20, 2012 | 2000 Pontiac Montana
PVC HID 1000 cards were getting stuck/bent in the Lamination module of our DTC550 printer. Talked to the tech department where we bought the printer/lamination module. They suggest because we are using...
Turning down the lam temp and dwell on the lam unit should have no effect on image color - they affect the processes only AFTER the printing of the card is complete. Make sure you were making adjustments to the LAMINATION settings, not the printing settings.
As to the noise, squeeks and groans emanating from the lam unit usually means mis-loaded lam film. Check the loading of the lam film in the printer and make sure it is not binding on the spools, and that the spools turn smoothly. Other than that, it could just be your printer showing signs of age. They have been out of production for more than 5 years, and do break down with age and usage.
Apr 28, 2017 | Fargo DTC550 Thermal Card Printer
What will happen to the hard drive in power failure?
Power failure as in whole house power failure? Or the computer's power supply failure?
Whole house failure, nothing, the computer will shut off and require rebooting, at which time you may receive a message the computer was not properly shut down, just continue as normal.
Computer power supply failure, same thing, nothing, except the computer will not reboot as the power supply has failed.
Jun 15, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Gateway 505gr became unresponsive, on reboot windows cannot load
Hello guys,
This problem would arise only when the motherboard doesn't work properly. Check with your nearest gateway service center to get your CPU work again. That would be the only thing to be done.
~REGARDS,
Jegan
Nov 20, 2008 | Gateway 505GR PC Desktop
Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Jul 16, 2008 | Fargo Pro L ID Thermal Printer
Fargo HDP5000 Thermal Printer Logo
1,994 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
