I replaced the motherboard due to a bad nic controller. the pc booted up and was working. I had no issues with the nic card. The pc was on its side with the cover off. all things were working. I stood the pc up right and installed the cover and the pc shut down, this is when the problem started. From that point the power would come on, fan was running, power to the mother board, power to the cd rom, ram in but the light stayed amber. I put the original motherboard back in, it was working as well except the nic controller now with the original mboard back in it still has the solid amber light.
  • 6 more comments
  • rlaporte543 May 25, 2011
    I see a green light for the network, and a solid amber power light. Both motherboards worked, I replaced the motherboard due to a bad nic controller. I installed the new motherboard and it was working while laying on its side, when I put it upright and installed the cover the pc shut down.
    Yes the amber light is the power light. I have disconnected and reconnected all the cables. Removed all the cables from all the components to see if it would boot to the bios, no go. Fan works, cd rom works, the power light on the motherboard is on. All the components seem to work. I have replaced the power supply as well. Both motherboards worked until I stood the unit up.
    No post screen. The monitor works. Using the onboard video. 2 - 1 gig memory sticks. The concern is both mother boards worked, until I had the first problem. Now either one works. ????
    No beeps. Have tried one stick and have replaced the ram with good ram as well.
    I have used this monitor on other systems and it works. I'm not sure what you mean by "black outed" the monitor is on with an amber light as well. When turning on the pc the monitor stays black, no beeps on the pc.
    I am in the process of performing that task right now. I need to leave in about 30 minutes, can I get back with you tomorrow?
  • rlaporte543 May 26, 2011
    I took another system board and processor from another pc and it worked just fine. I ordered a processor and will know for sure when arrives. If I close this how would I contact you to let you know for sure that it was the processor? Should be here Tue or Wed of next week. Thanks for the help. It was good to talk through the process.
    Yes it was good to talk through the process. Thanks.
  • 2,632 Answers
Welcome to Fixya. Just for verification would like to know which one has the solid amber light? I understand the question but i need to know which one has the amber light. another thing when you use the original motherboard is it working or you have the same issue with the new motherboard?Please provide the information needed to be able to help you with this problem.
Thanks
Posted on May 25, 2011
  • 6 more comments
  • Rofel Lantican
    Rofel Lantican May 25, 2011
    The amber light is the power light right? when the you stood the pc and it shut down can you turn it back on? Can you try to assemble the pc on a standing position or try to assemble it on its side and see if it will works again? Were trying to find out if this i just a cause of a loose cable or a problem with the board. Thanks
  • Rofel Lantican
    Do you have a display on the monitor or did you see the Post Screen? Or the there's a message on the monitor that it is looking for signal? Do you have a video card or your using the onboard display? How many memory sticks you have?
  • Rofel Lantican
    Can you try not to use both memory sticks just try to test it one by one. Let me know what happen. By the way do you here any beeps when you turn on the computer?
  • Rofel Lantican
    I see have you tried using a different monitor? Different Vga or DVI cable? Power running on the system but black outed right?
  • Rofel Lantican
    Blacked out means no display. Do you have the a same processor that will fit in on the old and new motherboard. What were doing now is finding out which hardware component fails. Because as you can see you already change the motherboard, Memory, PSU and the monitor and still the same can you try to use a different processor that is compatible with the old and new one see if you will be able to run it properly?
  • Rofel Lantican
    Sure not a problem. Just leave a reply on my message and i'll get to you as soon as i can. Test the processor ok. Thanks
  • Rofel Lantican
    Rofel Lantican May 26, 2011
    Even if you close this case you can still reply a comment on this question and i will able to reply that. Just let me know if you already have the processor. Thanks
  • Rofel Lantican
    Just let me know what happen. Thanks
Nic card not working? How to troubleshoot? Is there a plug and play nic card that can be installed onto this desktop PC?
Hello Sqis,
You can purchase any nic card which is compatible with WinXP or 7.
Insert the card in PC Slot of the motherboard.
Install the driver for the card and it will work.
May 05, 2011 | HP Compaq Presario SR1650NX...
I cant conect to the intornet. im using cable can u help mi.
First thing is check and see if you have a valid IP address (Start, run, CMD enter) type (IPCONFIG /All ) this will give you the IP address information. If result of IP address is 0.0.0.0 or 169.254.x.x then you don't have connectivity with your broadband connection (Bad Cable, Bad NIC, Other communication issue etc)
If no valid IP address, the 1st thing is to power off system, power off any router you may be using and power off the broadband modem. Wait 3 minutes. Power on broadband modem, wait a minute to let it reset, power on Router (If you have one) wait a minute for it to reset, power on system and test your connection. If no change, try a different computer at that connection see if it can access the internet. If another system works, it is likely the Network Interface Card (NIC) which on a Dimension 2400 is part of the motherboard (Buy a PCI NIC for $10)
If you have a valid IP address, boot to the safe mode with networking (F8 at boot) then see if you can connect, if so then your issue is software based (Firewall, security software, possible virus) If it doesn't connect then there could be issue with your TCP/IP protocol settings. If you can't connect in safe mode with net, reboot to normal mode, then right-click your local area network connection and click REPAIR and see if that doesn't resolve. If no change try an anti-malware program like Malwarebytes
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
New motherboard makes my wireless nic loose signal.
It sounds like a driver issue.
I assume you mean the card worked previously on an old motherboard.
Remove the wireless NIC driver and then re-install it. I assume their are no yellow exclamation marks agianst your NIC in windows system properties? To see sys properties right-click "My Computer" select Properties/Hardware/Device Manager. Look for the network adaptors section. You can update drivers from here on your wirless card or even try the Troubleshooter tab.
if you don't have the driver CD let windows go onto the internet and search for a driver.
If you rely on the wireless card to connect to your internet connection, perhaps you can connect your computer to the internet modem or router via your computers LAN/network connection?
If that's not possible, download the driver from the NIC cards manufacturer website and pop it onto a USB thumb drive which can then be installed onto your new computer.
Last thought, make sure you are only using one controlling application for your NIC ie you use either the Windows Zero Config Utility OR the NIC cards manufacturer utily eg D-Link, Netcomm, etc etc
That is not both at once as windows has a major hissy fit.
See:
http://forums.whirlpool.net.au/forum-replies-archive.cfm/438290.html
http://www.netcomm.com.au/__data/assets/pdf_file/0020/17291/61_Using.pdf
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1378157.html
Cheers,
Steve
Mar 07, 2010 | Abit AV8 Motherboard
When turn on nothing appear on screen
possible issue would be the LCD, video controller/card or motherboard. Connect an external monitor to the laptop. It works fine and the computer boots properly, it will be an issue with the LCD. Request an LCD replacement if in warranty, otherwise, purchase one. If same issue with external monitor, check for signs of system booting up. Listen if you hear the welcome sound that you usually hear when Windows has successfully loaded. If you get this, request a replacement for the video card. If video card is integrated to the motherboard, request a motherboard replacement.
Oct 27, 2009 | Acer Computers & Internet
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
LAN automatically disconnects while downloading and starts working only after disabling and again enabling the local area connection
With this issue it could be the Hardware / Software compatibility. The first thing to do is ensure the latest drivers are installed or the NIC. If the latest drivers are installed I would recommend replacing the NIC. They are less than $30 and they come with great drivers, and if the old NIC is onboard it would be advantageous to get it off the Motherboard. It would be best to open up the computer before you run out to get the new NIC and makesure the motherboard can support a PCI card. This card slips into the White slot that is about 3 inches long. If you have a White slot that is about 1 inch long this PCI card will not fit into it the card you will need is a PCI Express x1 NIC. The rest of the information you will need is provided by the NIC Manufacturer.
Mar 30, 2009 | Asustek S775 Intel X38 ATX Audio Lan...
Where is the NIC located on the gx270 dell machine. How do I
Look right above the sound ports, you will see a row of 2 usb ports and a port for a network cable
Nov 12, 2008 | Dell OptiPlex GX270 PC Desktop
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
Jun 18, 2008 | IBM NetVista A40 PC Desktop
Montior does not come on when computer boots
Hi. If there is no display activity at all (i.e., no boot screen logo, etc.) then it could be a bad video card. If you do get the afore mentioned items, boot into Safe-mode by pressing the F8 key at startup. If Safe-mode shows Windows, then it could be a driver related problem with the operating system. This unit has the Integrated Intel GMA 3000 video card, which means its built into the motherboard and with this computer being a space-saving design, you would have to find a half-height video card as a replacement should the internal video card be bad. I am not sure which replacement card you can get because I do not know if there is a PCI slot of AGP slot open on that motherboard. If I am assuming correctly, I would say that you get a "welcome" screen initially, but when the computer boot into the operating system, you don't see that. Please let me know if this is incorrect.
Apr 28, 2008 | Acer Aspire L310 (ASL310UD631A) PC...
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
