My Sony mhc-ec79i is displaying PROTECT on the screen can't do anything while this is up, please help
Open the back of the unit and remove the 5way ribbon and 7way cable plug from the main amp module and turn on power the LCD should display normal operation, then power doen and refit those plugs and repower again and all should be ok now, simlpy by turning of the power does not reset these units you have to remove these leads to force reset, check theat the fan is not blocked with dust and thbe speakers are ok and no shorted wires etc and the impedance is ok.
Posted on Oct 10, 2013
  • David
    David Jun 27, 2014
    how do you remove the 5 way ribbon and 7 way cable?
  • Rob Duthie Jul 31, 2014
    Just unplu un clip them
  • 87 Answers
SOURCE: The push power protect always
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Posted on Nov 16, 2010
  • 12 Answers
SOURCE: My Stereo Is Always On Protect Can It Be Easily Fixed
Protect occurs when 1 or more of your speaker wires is touching somewhere. Power off the receiver, connect speaker wires to receiver and speakers again, power back on, should fix the issue.
Posted on May 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: i have a sony MHC-GX2000 PROBLEM-
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 16, 2011
  • 127 Answers
SOURCE: sony str de 475 ?? is appear 'protect' on
The message appears usually when the wiring is wrong (short circuit) or the speakers are defective or their impedance is too small for the amplifier's output (for instance 4 ohms speaker connected to an 16 ohms output). First, check your connections.
Posted on May 15, 2011
dunnbiker
  • 8546 Answers
SOURCE: when i switch on my sony str-de375 receiver
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 02, 2011
Hello can u help me about my MHC-gzx55d sony hifi component, when you turn on the power, the screen display appear "PROTECT" what is the problem and what is the possible damage of my component. please help...
When it goes into protect mode it has been over loaded. Remove everything from the component and unplug the unit for a minute or two. plug it back in and see if it pops out of protect mode. If this does not work then you will need to do a factory reset or check the fuses on the inside of the unit.
Feb 20, 2015 | Sony Audio Players & Recorders
How do I remove the 5 way ribbon and 7 way cable from the main amp module of my mini hifi?
That unit looks like an economy model that is mass produced. It would probably not have quick connects on the boards. You are going to have to use a soldering iron.
Jun 27, 2014 | Audio Players & Recorders
Sony stereo protect mode
If "PROTECT" appears on the display: Immediately unplug the power cord, and check if anything blocking the ventilation holes on the back of the system after "PROTECT" disappears. After you have checked the ventilation holes and found to be all right, reconnect the power cord, and turn on the system. If the issue persists, contact your nearest Sony dealer.
The above is from the manual at http://www.docs.sony.com/release/MHCEC909IP.pdf
May 24, 2013 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
"Protect" Blinking on Sony Stereo
may i see a diagram showing where the ic goes?
Nov 03, 2012 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
Power protect
is' protect 'appears on display?.remove speakers & check again.if then set work without error check speakers & cable. protect appears again there is a problem with power amp module.
Jun 14, 2011 | Sony MHC-RG40 CD Shelf System
My stereo system blinks PROTECT on the screen
one of the out put tran is short ,
there normaly 4 to 8 of them
screw to a big heat sink ,
easy to get to.
check with a volt meter
then google the part
they cost 8.00-12.00
Mar 17, 2009 | Sony MHC-EC98Pi Shelf System
Displaying ' protect power ' on the screen.
Replace the audio amplifier IC because are damaged
Aug 29, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Sony 60 cd changer mhc-gs300av
The audio amplifier IC is damaged and need to be replaced
Nov 21, 2007 | Sony MHC-GS300AV CD Shelf System
1,120 people viewed this question
 Grubhead
Grubhead
