Question about Fellowes Office Equipment & Supplies
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
It worked!!! Now my Fellowes DM8C is working like a brand new shredder. At first, I cleaned the sensors several times and it did not work. Then, I disassembled the shredder head, removed the two sensors, cleaned them with a wet cotton towell, put them back in place, reassembled the shredder head and voilà! My shredder automatically starts when the sensors detect paper and stops a few seconds after the paper has passed through. GLEOSA
Posted on Jul 02, 2011
  • 610 Answers
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
Posted on May 25, 2011
  • gleosa Jul 02, 2011
    It worked!!! Now my Fellowes DM8C is working like a brand new shredder. At first, I cleaned the sensors several times and it did not work. Then, I disassembled the shredder head, removed the two sensors, cleaned them with a wet cotton towell, put them back in place, reassembled the shredder head and voilà! My shredder automatically starts when the sensors detect paper and stops a few seconds after the paper has passed through. LEO
Motor problem
It sounds as if the SafeSense is improperly shutting of the forward sensor. Call Fellowes and see if they can help.
If you do not have the manual use the link below:
Fellowes Shredder Manuals
Aug 18, 2014 | Fellowes 75cs Cross Cut Shredder -...
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
I have a DM8C that only runs for a couple of seconds at a time and then it stops. Toggle the switch back and forth and it feeds a little at a time until the page is completely shredded. It works okay in...
Common solution is to clean upper and lower sensors with cotton swab. If it still jams, then you will have to remove the top carefully and clean all paper shreds out of the housing. The paper shreds are most likely packed in the housing shroud and jamming or overloading the motor.
Jun 21, 2009 | Fellowes DM8C Cross-Cut Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Shreds halfway, then stops. Fellowes SB-95C
on the underside of the shredder, at the top of the space where the cuttings box is, there are 2 sensors, 1 at either end of the shredder blades. it sounds like these sensors could be either dirty, or defective. try to clean these with a cotton bud or similar. it may need new sensors, bu it is worth a try!
Jan 30, 2009 | Fellowes SB95C Cross-Cut Shredder
PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
WITH MACHINE OFF
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
572 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
