Question about Air Tools & Compressors
Ac won't blow lights on dash says it's on no air
    Problem Solver:
  • 20 Answers
Need more info ------------- year //make //model --------- sounds like a/c relay not energizing , which the ground side is controlled by the ecm or bcm . ---- possible bad relay // wiring // fuse// compressor
Posted on Jun 06, 2011
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
No heat from vents
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
Air conditiner cools on right side but not on left side
It can be issue with blend door actuator or vacuum leak or loose vacuum hose connection.
I suggest you few help links.Click the link below and follow the troubleshooting.
A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
A/C blows Cold From Defrost Vent Only? http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
A/c Blows Warm on driverside? http://whatisbyme.blogspot.in/2012/06/2007-kia-spectra-ac-blows-warm.html
A/C compressor clutch won't engage http://schematicsdiagram.blogspot.in/2012/04/2000-cadillac-deville-ac-compressor.html
Ford : A/C blows Warm? http://whoisbyme.blogspot.in/2012/06/2007-ford-freestyle-ac-blows-warm.html
Thanks.
Jun 26, 2012 | 2005 Ford Five Hundred
Ac vents not working
There is a blend door acuator which moves when u change your settings. Its a electric motor. Down under dash, Will need a mech and a heating and cooling diagram to find where the motor is,
Jun 13, 2012 | 2007 Ford Sport Trac Limited
Air does not blow from the center dash vents
My ac is only blowing on the defrost but none on the center dash vents. How do I clean the ac hoses? It may be blocked.
Apr 04, 2012 | 2003 Chevrolet Cavalier
99 GMC Sierra 4.8 1/2 ton 2 wheel drive new body style ac does not blow cold air from the front vents on the dash? Still get some cold air from bottom by floor vents,
if both vents are blowing air in general then you may need to get your air conditioner recharged, but if the front vents aren't blowing at all then you may just have a jammed vent flap and you can fix that from under the hood next to the blower motor. check you rowners maual for the exact location
Jul 01, 2011 | GMC Sierra 1500 Cars & Trucks
I have an 1988 Chevy Silverado. The AC blows cold but for some reason when I move the AC from the "feet" section to blow from the top vents, it doesn't change. Now the AC is stuck just...
Yes, you have a vacuum line that has come off, cracked or broke somewere under your hood. It's possible under dash vacuum diaphragm could be bad, but not likley....hope this helps you??
May 25, 2011 | Chevrolet Silverado Cars & Trucks
Well i have a 2001 S80 my AC is blowing cool on the passager side and hot on the driver side what can i do to fix it.
You will need to replace the Acuator for the Internal Baffle inside your dash for the Driver's side A/C vent. The Actuator is not opening or closing the baffle to give you hot or cold air.
Jul 17, 2010 | 2001 Volvo S80
Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
Jan 18, 2009 | 1997 Chevrolet K1500
Air Tools & Compressors Logo
52 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
