Question about Toshiba 61H70 61" Rear Projection Television
Toshiba 61H70 I have a 61H70 Theaterview that is about 8 years old. When I turned it on after it being off for about a half hour, the only input that works is the ColorstreamHD2. The picture on that input is perfectly clear. On input 4, the screen is black with the lettering for the input menu screen garbled. When the DVD player is turned on, the screen becomes pink with black horizontal and vertical lines that move around comes up. The others have audio, but the picture does the same thing with the pink screen with black lines. Any ideas?
  • timmbo23 Aug 16, 2008
    Do, it is very simple and crude waving horizontal lines, with a pink and black background.
  • johnson28 Aug 23, 2008
    I have similar problem. Only HD receiver with component o/p is working ( on last two component channel). All the other channles are garbled and un readable. Any suggestion what causing this?
  • 2,337 Answers
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Posted on Aug 16, 2008
SOURCE:
Tip
Toshiba 61H70 Service Manual Download
Download Toshiba 61H70 Projection Television Service Manual
Models: 50HX70 / 55HX70 / 61HX70 / 55H70 / 61H70
Have you misplaced your Toshiba 61H70 Projection Television Service Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television Service Guide?
Follow this link
(& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television troubleshooting & repair instructions.
I hope that helps.
_______________________________________________
Toshiba 61H70 Manual Download
on May 10, 2010 | Televison & Video
Tip
Download Toshiba 61H70 Projection Television Manual
Have you misplaced your Toshiba 61H70 Projection Television Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 61H70 Projection Television User Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 61H70 Projection Television instructions.
I hope that helps.
Toshiba 61H70 projection TV. Perfect picture but the sound suddently stopped working. Tried all on screen settings and still no sound. Set is 8 years old but relatively few hours. Is it worth repairing?...
it sounds like the soundboard went out on the tv..its probably worth fixing but you have to know what you are doing if you do it on your own.it could be something more minor too but not sure
Feb 24, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba Theaterview HD 52
On my toshiba I just use the input button on remote.
May 12, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Tip
Follow this link
I hope that helps.
on May 10, 2010 | Toshiba 61H70 61" Rear Projection...
Tip
I hope that helps.
Need Blue Lamp
I would think you would have to get one in America most likely at bestbuy or Circuit City. Hope this helps. =)
Feb 25, 2008 | Toshiba 61H70 61" Rear Projection...
Toshiba theaterview
What is the model number?
Jan 03, 2008 | Televison & Video
Toshiba Theaterview HD 52"
I have the same tv and had it fixed the problem is most likely the power supply a $50.00 part but I suggest you have a repairman do the fix. Total cost should be around $250.00 for labor and parts.Also unplug your tv for over 4 hours then plug it back in to see if it works they call this a hard reset.If this does not work after 4 hours try unplugging it overnight and then try it. That is what I did to use the tv until I got it fixed. The only thing it could be is the convergence circuitv if this is the case it should cost about $400.00
Dec 02, 2006 | Toshiba 55H70 55" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
284 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
