Question about Craftsman Garden
Sears 917.258591 the belt broke I replaced it and within 30 minutes chewed the belt please help
4 Suggested Answers
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
  • 100 Answers
SOURCE: I have a sears ridering lawn mower . The problem i
is the belt in alignment? check pulleys without belt on are there any with notchy or harsh bearings? are the belt guides too close to pulleys causing belt to heat and fail?
Posted on Aug 14, 2010
  • 377 Answers
SOURCE: Old Hoover Convertible Upright U4109 keeps
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Posted on Sep 05, 2010
Remove front panel
It was a broken dryer belt. Called Sears. No help ay all. No parts in the sears store.. Called Winklers Appliance 3705 Transport St., Ventura, Ca. 805.642.5103. Brought them the dryer belt. $ 18,95 . They told us what to do. Sold us a belt and we were fixed in 30 minutes at home, by our selves.
Mar 19, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I need the belt for the west bend 41073. put ingredients in today and after a few minutes it wasn't mixing anymore. The belt broke.
please measure the belt in inches and let me know the size. I may have one that will fit. Try to get it within a 1/4 inch such as 22 3/4 or 21 1/4, 19 1/2 etc. etc. Thanks, Daryl
Aug 24, 2011 | West Bend 41072 Bread & Dough Maker
I am looking for belt size for HABAN 24577 snowthrower to Murray 18hp lawn tractor. Book doesn't provide size info.
I have a Haban Model No. 24577A 42" front mounted snow thrower attachment, which I have mounted to a Murray lawn tractor. I needed to replace the lower drive belt, labeled: V-Belt-Long Part No. 23948 in my Haban manual. I had found it next to impossible to find a replacement belt part number or cross-reference to other brands. I tried many belt sizes and lengths to no avail - belts broke quickly and suddenly after 1 or two uses.
While researching Haban on the internet, I realized that they also supplied snow thrower attachments for Sears Craftsman lawn tractors. A thought hit me at one point in my research... that Haban probably sold the same snow thrower chassis to all manufacturers, but only with different interfaces to the tractors. So I ordered up a belt for a different Haban model that was supplied to Sears, and I think that my intuition was correct!! I have found a belt that works with my Haban Model No. 24577A snow thrower.
The belt that appears to be a direct replacement for the Haban belt part number 23948 (long) is as follows: Kevlar Blue V-Belt 5/8" x 87". It is sold by several suppliers under various part numbers, priced at $20 to $30.
I hope this helps you.
Jan 19, 2011 | Garden
While driving this afternoon, my 2001 C-320 displayed that my battery/alternator needed immediate repair (or something to this effect). Within minutes, it started to overheat, reaching 120 degrees Celcius...
You need to get the belt back on. You can't drive the car without it. Also you need to find out if the belt was just old and broke or if a part went bad, like an idler pulley or a tensioner , and replace it as well so the new belt will stay on.
Nov 09, 2010 | 2001 Mercedes-Benz C-Class
I have a sears ridering lawn mower . The problem i am having have replaced the belt but it keeps chewing it up.
Aug 13, 2010 | Craftsman Garden
My belt broke on my model 139.655000 sears robust automatic garage door opener. I have misplaced the belt and don't know the length of the belt to buy a replacement. Do you know the belt i need?
The part number for this belt is STD303310 and is available from Sears for $4.49. I would almost bet you that any good door opener service company in the yellow pages would have one on the shelf.
Aug 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blower Belt
That is were the belt rides on the shaft. The belt either broke or slipped off. Replace the belt if you can. Sears can help you with that.
Oct 17, 2009 | Dryers
Liftmaster 1/2hp problem with shredding gear shift really fast
DOES THE DOOR WORK SMOOTHLY AND EASILY MANUALLY??
IF NOT THAT WILL CHEW UP YOUR GEARS.
IF THE DOOR WORKS WELL MANUALLY I AM GUESSING YOU ONLY REPLACED THE EASY GEAR.
YOU NEED TO REPLACE *BOTH* GEARS - FOLLOW THE INSTUCTIONS COMPLETELY. THE SECOND ONE IS HARD TO CHANGE BUT IF YOU DON'T THE ROUGH SURFACE OF THE HARDER WORN GEAR WILL CHEW AT THE NEW GEAR AND ..... WELL YOU HAVE SEEN THE RESULTS.
HOPE THIS HELPS
Mar 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
29 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
