Question about Sharp CV-P10MX Air Conditioner
Ive had this air conditioner over 2 years and never had this happen it cuts off and all three lights flash i read the back it says if it does that to drain it i dont have the hose your supposed to have to drain it but i just drained it into a pot. i done exactly what it said and then cut it back on it runs any where from 5 to 30 minutes then shuts off again. it doesnt make any noises it seems to run fine when it does run it just keeps shutting off. i dont know if thats the exact model but its close to it.
KOakaKO
  • 135 Answers
SOURCE: "Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Posted on Aug 04, 2007
kstfas
  • 75 Answers
SOURCE: air conditioner leaking
Hi, There are no pipes, just passage ways on a window unit. It probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit through passage ways to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt or algae in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem. Since the tilt is right and it doesn't seem to be freezing, Maybe a temporary increase in tilt and a dropper of bleach at the base of the evaporator would do it. This will kill the algae and may unblock the water flow. NOTE: It may also cause stains on a carpet or floor if the bleach water drips onto it. If you want to pull it out and clean it, most units can be pulled out of the housing and sprayed with a water hose but you need to be careful not to get water in the electrical parts of the unit. They can be covered with plastic or foil. Make sure you unplug the unit before trying to remove it. You may have to remove some screws to remove it from the housing. Hope this has helped. kstfas
Posted on Sep 19, 2007
SOURCE: reset air conditioner
This did it for me! Same procedure but its described a little more thoroughly here...
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Posted on Jul 21, 2008
  • 905 Answers
SOURCE: E1 Flashing on display, air cut off
There are steps listed in the user manual which can be downloaded from:
http://www.sharpusa.com/...
/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf
You also need to hold the power button when plugged back in. If that doesn't work, there is another step as well.
Posted on Aug 25, 2009
lambocar
  • 31 Answers
SOURCE: Air conditioner will only run a short time then shut off.
Manula or online site will tell you what e-1 is, I would think it is a power outtage reading and unit needs to be reset. Dont be afraid to call your units manufacturer and ask tech how to reset unit with an E1 error.
Posted on Jul 07, 2010
I have a frigidaire fra123cv1 every 3minutes it cuts off and comes right back on. Then the #88 shows up really fast... then goes back to normal seting
Good morning jesse dixon, I appreciate your post!
Based off the information you have provided your Frigidaire air conditioner, FRA123CV1, cutting off every three minutes and then flashes "#88" then it will go back to the normal setting. Sounds it could be a possible issue within your control panel or power cord. Are you currently under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy. I hope this helps to some degree. -Matt
Aug 25, 2014 | Frigidaire Heating & Cooling
I have a daikin split air conditioner after been on for 10mins it flashes L1 and cuts off,we have been waiting 4 weeks for Blueline to replace the boards as they said that was the problem since they...
Very simple. Please follow these steps.
1. Power off. 2. In three phase compressor terminal or in terminal block-interchange any two wires.
Now power on and start. Hope, you will be happy.
Feb 26, 2011 | Cfm Daikin R410a Split System Air...
Please help i got a LG r12awn split and the heating light flashes twice followed by one flash on the cooling, ive read through the manual and cant find any thing about it
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor. Thanks.
Feb 05, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
The ! light is flashing and will not turn on
hi simply empty the reservoir located on the bottom back of the machine. this was my first empty and ive owned it for 4 years...simplest solutions to the hardest problems...
Aug 11, 2010 | Amana Haier AP125HD Air Conditioner
Samsung Air Conditioner will not turn back on after power Outage
disconnect the units from their power source and wait about an hour. Reconnect to power source and see if this has reset the units.
Hope this helped you good luck on the repairs
Dave
Nov 11, 2009 | Samsung AW1403B Air Conditioner
Fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Jul 04, 2009 | Fujitsu 24R1 Air Conditioner
My MSH 024 Air Conditioner keeps tripping off at the mains switch
FIRST TRY TO CHECK THE CIRCUIT BREAK THAT IS CONNECT TO THAT AIR CONDITION, USUALLY IS A 30 AMPS OR 40 AMPS CAPACITY, MAYBE IS BELOW THE AIR CONDITION CAPACITY AND OVERHEAT THE BREAK, OTHER WISE UR SHOULD CALL A TECHNICIAN TO CHECK THE COMPRESSOR AND THE COIL OF THE CONTACTOR
Mar 09, 2009 | Comfort-Aire MSH-024 Air Conditioner
Ac runs for a while then stops and operation light flashes
Hello, It depends what refrigerant the system is on but if it tripping out on HP it could be overcharged with gas or a problem with the outside condesor fan.
Feb 02, 2007 | Mitsubishi MS12TN Air Conditioner
Sharp CV-P10MX Air Conditioner Logo
67 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
