Question about Philips Audio Players & Recorders
I have bought a Philips Hi-Fi DCM 377/12 and an Ipod Classic . However, after 15 minutes playing time the Hi-Fi system shuts down and leaves the Ipod still running but unable to be heard. I have checked the Sleep timer is NOT on. Also. the remote control works everything except the Ipod! Regards Alan Bartrop
  • 4 Answers
SOURCE: aiwa compact disc /2disc player
Same problem here...I determined that if you unplug the receiver for a few hours, it will work again for a week or so.  Someone else on this website said that it had something to do with the power relay switch:
http://www.fixya.com/support/t190750-aiwa_av_dv75_powers_off
Posted on May 31, 2008
SOURCE: I have a Hitachi AX-m133
Hi
I recently got one of these and had the same problems. These were solved as follows.
Firstly, for small devices such as USB sticks and MP3 players they must be formated as FAT32 otherwise they cant be read, NTFS does not appear to be supported.
Secondly, for portable hard drives they must be also formated to FAT32 they also need to be externaly powered. For my 2 1/2" lap top drive the power from the USB port on the machine was not enough to fire up the drive I had to use a Y cable plugged into a mains usb charger to boost the power it then worked fine. Also be a little patient as it will take a little while to read the drive, this will depend on the drive capacity but you should hear the drive ticking over as it does this
Posted on Jul 12, 2008
localwonder
  • 6784 Answers
SOURCE: WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
Posted on Mar 16, 2009
  • 4234 Answers
SOURCE: Shuts down by itself
If there are no speakers connected and you still get the protection message, there is a problem internally. Exchange the unit while you can. The typical parts required to fix this problem will be over $75 US.
Dan
Posted on Mar 25, 2009
  • 239 Answers
SOURCE: power outage and now control 4 remote will not turn on equipment
Unplug it and replug it, press the on button
Posted on Sep 03, 2009
How to turn off the device
To shut down your iPod Classic, simply hold down the center button and the play button at the same time until the display shuts off.
To ensure that it stays shut down, flip the "hold" switch to disable button input.
Sep 14, 2014 | Apple iPod classic MP3 Player
My ipod restarts after playing a certain song
UM i dont know if this will work but connect your iPod to the iTunes store with your UBS cord and something will pop up click yes something else will pop up click no then leave it an hour and i think it will work .
Apr 28, 2014 | Apple iPod Audio Players & Recorders
System shuts down after 10 minutes while listening to mp3s
Please check if the iPod is fully charged , if not allow it to charge for about 8 hours and then try if the fault repeats. If so the iPod must be connected to a PC and all the files must be scanned or removed. The format the drive and reload ONLY with safe files with which you can try once again.If fault appears the chances are the battery or the processor hanging up which might need technical help and consensus.
Nov 30, 2011 | Philips HTS3051B/F7 Theater System
How can i get a user manual for the Philips DCM 250/37
I suggest visit this link to download this PDF document: dcm250_37_pss_aen.pdf
Hope this helps (remember to rate and comment this answer).
Aug 17, 2011 | Philips DCM230/37 iPod Docking Executive...
Cd stuck in philips dcm 230
I had the same issue today and came up with a solution...maybe not the best, but it worked. I unplugged the unit and then holding it by the sides (which I was sitting down) struck (not too hard) the unit onto my knees. Be sure you are holding the unit with the CD opening facing the floor. You may have to do this a few times, but the CD should start to come out, after which you should be able to grab hold of the disc and pull it gently out. Once I did this, I inserted another CD and everything worked fine. Being the daring type (obviously), I tried the original CD again, and like the first time it got stuck again and I had to repeat the same process. I came to the conclusion that for whatever reason, the CD was bad and tossed it out. Any other CD I put in the unit works just fine. Bottom line, it may be crude, but it works!
Jul 13, 2010 | Philips DCM230/37 iPod Docking Executive...
Hi,i've got a ipod classic and i want to hear it on the speakers
Hello
Ok, if you have the mini jack, you are half way there, you need a cable wich goes from mini jack to rca. Just plug in the mini jack cable into your Ipod and the rca cbles into the back of the HI FI in a input. Now just set the HI FI to the input device and you should be set. Hope this can help.
Best regards
Andrea
Nov 04, 2009 | LG LX-221 CD Shelf System
Logitech Pure-Fi Anywhere Portable Speakers for Apple iPod . It keeps shutting off after a few minutes. It's plugged into a wall outlet.
Many have reported the same issue, reset the pure-fi with the reset switch (on bottom) while it is turned on, then put your iphone/ipod at 75+ % of volume before/while playing.
Feb 21, 2009 | Logitech Pure-Fi Anywhere Portable...
Dvd does not play
Three problems - the Media Converter will not correctly convert videos over 15 minutes long, it will not recognize the DVD's file structure, and it cannot play copyright-encrypted video files. This player is more for YouTube-style videos. Here is a workaround:
1) Use video editing software to break the DVD file into 15-minute chunks
2) Run the chunks through Riva FLV Encoder - convert it to AVI format, and make sure sound is enabled
3) Run the Riva-converted chunks through the Philips Media Converter
4) You can now watch your movie in 15-minute chunks - I hope you chose filenames that allow the files to be played in sequential order
Have fun!
-Tha Mp3 Doctor
Dec 26, 2008 | Philips GoGear SA3245/37 Digital Media...
Certain songs on my iPod that I bought with iTunes just will not play when I upload them
Do they play ok in itunes?
Try resetting your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 26, 2007 | Apple iPod MA446LL/A MP3 Player
Power cuts out
This problem happend to my sony system about a year ago. It was the amp that blew in mine because of the fan inside the system was not coming on when it should of. I found that when i had put my PC in the AUX jacks it blew the fan on me, so every time the volume got to 15 the system would just shut down and not come back on at all, or it would need time to cool down before it would start up again. Take it to a shop and get it looked at by someone that knows what there doing. Please dont try and do this yourself.
Aug 14, 2006 | Aiwa NSX-AJ205 CD Shelf System
147 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
