Question about Vipower USB 2.5IN HDD SLIM ENCLOSURE, VP2528SA2 (1630179) Drive Case
My computer suddenly cannot read my portable ViPowER VP-2528SA2 USB 2.0 pocket drive I have another drive and switched cables and this not help.
My Samsung G2 Portable Suddenly stop working and my computer can't detect it. I'd try to another computer but still they can't detect it. I don't know what to do. pls help me.
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
Sep 04, 2012 | Samsung G2 Portable External HX-MU064DC/...
Need an operating Manual for a 1T omega portable hard drive USB 2
There should be no need for a manual for a USB 2 External Hard Drive. Simply plug it into a USB Port on the Computer and select it with Windows Explorer. Basically, It will assume a Drive Letter other than C: or D: dependent upon how many drives you computer has. A Tower with a CD Read Only drive and a CD or DVD burner drive will have C: primary Hard Drive, D: typically assigned to the read only drive and E: CD or DVD Burner drive. Windows explorer will display all Connected Drives. If it doesn't show up there it is probably a fractured wire in it's cable or a damaged contact it the USB connector on the cable.
Nov 18, 2011 | Iomega Computers & Internet
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Usb 2.0 portable drive has (5pin mini) will only work with usb cable that came with canon camera. other brand new usb 2.0 cable won't work. Tried this with 2 different drives and also with mac and PC
Suggestions:
(best to worst)
1. Use a "Y" USB cable with that drive.
2. Use a shorter USB cable.
3. Use the new cables with the canon
4. Use a 2.0 hub
The drive should have come with a "split" USB cable (USB "Y" cable). The drive requires a "data" and a "power" connection to your computer.
Get one at Radio Shack, Best Buy, Office Depot/Max... ($10)... or Dollar store ($1.09)
Oct 02, 2009 | Toshiba 200GB USB 2.0 Portable External...
Pc doesnt detect/read portable HDD, but a USB connection appears on the task bar
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Sep 05, 2009 | Toshiba 120GB USB 2.0 Portable External...
Lost all my stored info
Aug 30, 2009 | Verbatim SmartDisk Firelite Portable USB...
The drive not reading
Hello folks,
Sounds like both units are suffering from hardware failure. The most likely culprits are failed USB/1394 to IDE/SATA circuitry or failed drives.
The simplest test/solution is to buy a new, empty, drive enclosure and transfer your drive into it. Test that enclosure, if it works, the drive is fine your done.
If it doesn't the failure is in the drive itself and if you have important files on the drive you will require the help of a pro. State your region and city and I will give you a recommendation for a professional data recovery service.
Chris
May 28, 2009 | Iomega (33222) 80 GB Hard Drive
Help with Maxtor onetouch 4
The Maxtor OneTouch 4 Mini is a portable hard drive, with USB interface.
What you have to do is, just connect your Maxtor OneTouch 4 MiniT to the one end of USB cable, after that insert he other end to your laptop USB por.
Wait for few moments your operating system will read your new connected portable hard drive.
After that you can find a new drive letter in your My Computer, thats for your portable disk drive.
thanks
Iqbal
Mar 10, 2008 | Computers & Internet
Hi, Chinmay
                      You have to look into first all of  drive's externale power adopter , and then after usb controller cheap beacuse controller is the media of communication between usb protocol and ide protocol
Oct 14, 2007 | Iomega (33222) 80 GB Hard Drive
Vipower USB 2.5IN HDD SLIM ENCLOSURE, VP2528SA2 (1630179) Drive Case Logo
134 people viewed this question
Top Vipower Computers & Internet Experts
David Payne
David Payne
Are you a Vipower Computer and Internet Expert? Answer questions, earn points and help others
