Question about Friedrich QuietMaster Electric SS10J10AR Air Conditioner
On my SS10 Friedrich AC, now got the fan to work and cooling working, but fan sounds like a motor boat. Unit is only 9 years old. Should I call someone in to look at it for $90.00 or is it time to replace it.
SOURCE: Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Posted on Oct 16, 2007
  • 5 Answers
SOURCE: Friedrich model ss12j10 --compressor does not go on. Any possible
the refrigerant leaks or the thermostat is not working. i also got the same same problem and have the thermostat replaced by a technician
Posted on Aug 21, 2009
  • 47 Answers
SOURCE: WOULD LIKE TO KNOW IF THE FRIEDRICH SH15L30-B UNIT
It is true that it is a sealed unit and should never need charged with freon unless a leak has developed. Most service techs will tell you that they cannot be recharged because you do have to break into the sealed system with a solder in valve or a line tap. They hold such a small amount of freon that finding and fixing the leak can be next to impossible and time consuming. Make sure that the inside and outside coils are clean. The outside fins can be brushed with a semi-soft brush like a toilet brush and then washed out with water. Make sure your power is off first. If the coils are dirty it will act just like it does if the refrigerant is low. 75 to 80 percent of air conditioner service calls are solved by cleaning the outside condenser coil. Brush up and down and do not put so much water pressure on it that the cooling fins start bending.
Posted on Jul 05, 2010
heatman101
  • 43501 Answers
SOURCE: Friedrich QuietMaster SS08J10R Air Conditioner is not working
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
heatman101
  • 43501 Answers
SOURCE: SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Posted on Oct 03, 2010
What causes a repetitive, rapidly repeating, hammering or slapping sound in my rv roof top ac?
It's sounds like a critter may have started to make a nest in the blower motor fan. I recommend trying to clean out the fan motor squirrel cage.
Aug 02, 2014 | Heating & Cooling
After turning the unit off, there is a hum for a few minutes, no fan noise, just a hum, and then it turns itself off eventually. The unit is about three years old and is otherwise cooling the room.
From what you have described, it sounds like the fan motor may be seized. In which case, it should be replaced. Depending on the age of the unit, it may be better to replace it than repair it. As parts and labor to repair it, can be almost as much as purchasing a new unit. As the motor assembly alone, runs about $150.00 + Labor.
I hope this has helped you and thanks for choosing FixYa.
Aug 10, 2011 | Friedrich CP10C10 Wall/Window Air...
I have an 8 year old Friedrich model SS10J10AR unit. The unit keeps shutting off when in cooling mode. When I leave it in FAN only it runs. I tried to reset the circuit board by hitting "Money...
Honestly, repairing and 8 year old AC unit (assuming parts are still available) can cost almost as much as buying a new one. If this is the first time you've had a real problem with it ... You've gotten your monies worth over the past 8 years. But, the decision is yours to make.
Thanks for choosing FixYa.
Aug 10, 2011 | Friedrich QuietMaster Electric SS10J10AR...
My 9 year old 17,500 BTU wall mounted window Unit is freezing over with little air coming out. New filter & clean coils still have same problem.
Sounds as though the indoor fan is about to give up the ghost.. 2 choices . 1 start looking for a newer more effecent unit. 2 replace the fan motor.. sorry but it does not sound good..Wiat I just thought It just might have a run capasitor ?? Not sure.. But it could be going bad as well .. Justa thought on that one. either way you can call a tech or buy a new unit.
Aug 08, 2011 | Friedrich Heating & Cooling
My Freidrich air conditioner is 2 years old. It seems to run very "rough" - it's hard to explain the sound I'm hearing. Still cooling off the room.
Sounds like your unit is maybe unlevel causing the fan blade to rub or its not draining properly and the fan blade is running through water and should be pulled and cleaned.
Jul 27, 2011 | Friedrich Heating & Cooling
Friedrich KStar KQ06J10 Air Conditioner not Cooling?
mcdevito75 here, Put the fan on and wait 3 minutes, NOW turn to low cool and place temp to 0 degrees or 1/2 thru the blue section of the cooling knob. Unit should work fine. type in online the unit name plus.com for any other assistance manuals, etc.
Jun 22, 2010 | Heating & Cooling
Oustide unit fan won't work
It sure sounds like the out side condenser fan has gone out.If you need to Fix a water hose to run on it like a spray fanning out over the out side coils(condenser)and try and see if it will cool.It will do the trick,until you get it fixed on week days.If I can help,let me know.>>>roniecon@gmail.com
Aug 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Compressor turns on but fan does not, fan motor is not siezed up rv is only one year old. but ac has not been turned on for 9 months.
Ok, the easiest way to check this is to remove the upper shroud of the AC unit. Have someone inside the coach while you are up there, have them turn the thermostat to ON/High Fan. If the fan does not come one, spin it by hand to see if that gets it going. If that works, let it run for a few minutes, shut down the AC and then lubricate the shaft points on the motor (WD-40 works). Try the unit again, if it does not start on its own this time, then you probably have a bad fan capacitor. It is located in the upper unit inside the small access panel. Two brown wires attached to it.
Hope this helps,
Jeff
Jul 04, 2009 | Dometic Rooftop RV Air Conditioner
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Friedrich QuietMaster Electric SS10J10AR Air Conditioner Logo
47 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
