Question about HP Photosmart C6180 All-In-One InkJet Printer
Ink Cartridge Error 2
I have tried buying new ink cartridges and they still do not work what is the best solution if it is a hardware issue.
    Novelist:
  • 183 Answers
Resetting the All-in-One
  • Press the On (Ink Cartridge Error 2 - fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Posted on Aug 19, 2008
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
My printer is reading error E5... what does this mean?
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 15, 2011 | Canon PIXMA MP210 InkJet Printer
HI When I switch on my MP 150 Printer the following error displayed E 5. Kindly help me to rectify this error. Thank you.
May 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Installed new black and color cartridge.
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
Are they Canon ink cartridges?
Remove the cartridges, make sure that the tape is removed , and re-install them. Make sure they are seated correctly.
For future reference , these are the error codes for your printer.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Ink tank
Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
  • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Help
Me is Vikram Kumar Thumu, I have seen your message on the  issue related to the HP Deskjet 5150 Printer. I would like to provide my suggestions on this issue.
The issue could be happen due to following below reasons:
1. If you are using wrong ink cartridge for the Printer.
2. If you are using a refilled ink cartridge
3. If there is an issue with fault with ink cartridge or an issue with ink cartridge slot in the Printer.
4. If there is an issue with Hardware malfunction of Printer.
Well, to resolve the issue I recommend you to try below solutions.
Note **: Your Printer supports below ink cartridges:
Cartridge Part number Black HP 56 (C6656A) Tri-color HP 57 (C6657A) Photo cartridge (optional) HP 58 (C6658A)
Check whether you can installed correct ink cartridges for the Printer or not.
Solution 1: To Hard Reset Printer once.
Make sure that Printer is disconnected from the computer.
1. Turn ON the Printer.
2. Raise the top access door of Printer. The carriage assembly should move    towards center of the printer.
   Note: for some printers carriage will not move to center.
3. Remove both ink cartridges from Printer.
4. Power OFF printer by pressing the power button of the Printer.
5. Disconnect the power cord from wall outlet and Printer cable (USB or Parallel) from the back of the Printer.
6. Let the Printer remain disconnected for at least 60 seconds.
7. Reconnect power cord and Printer cable (USB or parallel) at back of end Printer.
8. Turn ON the printer.
9. Reinstall both ink cartridges into Printer, make sure that they lock into position and installed in correct ink cartridge slots.
10. Close the top access door firmly.
once if you are done with steps, check the issue. If the issue still persists then please go ahead with next solution.
Solution 2: To Clean the ink cartridges and Cartridge slot in the Printer
Please open below web link.
Link is:
Once if you have opened the web link, please perform the steps that are mentioned in the web page for cleaning ink cartridges and also steps for cleaning ink cartridge slot assembly in the Printer.
I hope that this should resolve the issue. However, if the issue still persists then please go ahead with next solution 3
Solution 3: Testing the ink cartridges of the Printer
To isolate the issue by testing the Printer Hardware functionality with " Reserve mode printing " ( this is also called as 'Back up mode'). This is referred as using the Printer with only single ink cartridge. Your Printer model supports for this feature.
Steps are :
1. Open top access cover of Printer and remove the Black ink cartridge from Printer ,make sure that Printer is installed with Color ink cartridge only . Then close the top access cover firmly. Please turn off Printer and Wait for 30 seconds and then turn ON Printer. Check the status of blinking lights on the Printer. If you do not see any blinking lights on the Printer front panel, then cartridge is fine. We can now go ahead with testing Cartridge functionality along with Hardware test of Printer.
Please do these below steps to test Cartridge and hardware of Printer:
1. Turn the printer on.
2. Press and hold the POWER button until step 4.
3. Press the RESUME button four times.
4. Release the POWER button.
This should print a self test page. If you see any information printed on the page, then it confirm that Printer and cartridge is fine else if there is no information printed on the page then it confirms that Cartidge is Out of ink.
Note: you may receive a error code on the test page, please do not worry about that.
Please do below steps similarly to check the issue with Color ink cartridge..
Open top access cover of Printer and remove the Color ink cartridge from Printer ,make sure that Printer is installed with Black ink cartridge only . Then close the top access cover firmly. Please turn off Printer and Wait for 30 seconds and then turn ON Printer. Check the status of blinking lights on the Printer. If you do not see any blinking lights on the Printer front panel, then cartridge is fine. We can now go ahead with testing Cartridge functionality along with Hardware test of Printer.
I hope this should resolve the issue. If the issue still persists then you may need to service the Printer once.
If you any issues related to the Printer further you can mail me at thumuvikram@rediffmail.com. I will be glad to help you.
Oct 03, 2007 | HP DeskJet 5150 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
