Question about Southbend 460DD-2TL Gas Kitchen Range
I recently moved into a house with an old South Bend stove: the 6-burner, 2-oven, open broiler, and griddle model. I don't seem able to light the pilot lights, but can light the burners with a match with no problem. However, the oven is a different matter. When I hold a match to the center hole in the oven floor, as seems logical, a flame just under the hole lights up but doesn't spread until there is a build-up of gas, at which point there is a small, but scary, explosion. This can't be right. it nearly blows the door off. Am I doing something wrong or do I need to call a repairman? Do you recommend anyone in my area who can service vintage SB ranges?
2 Suggested Answers
  • 3 Answers
SOURCE: the southbend 436d range gives a yellow flame at the burners
This model Southbend range is "built to order" for the gas type.
Orifice alignment is critical on this model especially on propane, so make sure that the orifices are pointing directly down the burner venturi tube.
Also, the air shutters for the open top burners will probably have to be wide open.
If you are in an area with an elevation higher than 2000 feet above sea level, you will have to run a smaller orifice.
Those are nice ranges. Good luck!
Posted on May 19, 2009
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGST307&siteCd=WHRCOM&userType=Consumer
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
With the Jenn-Air PRG4810NP (Natural Gas), is there any way this can be converted to LP with a regulator? I'm not sure if I ordered the regulator for the LP range and attached it to the NG model, if this...
Conversion is usually accomplished by flipping the regulator cap around. Nat side is hollow and LP is solid to hold the regulator open. The oven orifices are adjustable and the surface burnres can be either adjustable or have LP replacements.
Eric
Jul 01, 2009 | Jenn-Air PRG4810 (NP) Gas Kitchen Range
Broiler doesn't lite, no gas going to pilot
Most cases Broiler ignitor is out, after you turn on the Broiler, check the voltage on Broiler ignitor 2 wires, if you have approx. 110v, then change the ignitor, but you don't have 110v, then check Broiler safety valve and oven thermostat, but 90% of the time is the Broiler ignitor. Have fun.
Jun 29, 2009 | Dynasty DGRSC 48-6G Gas Kitchen Range
Cleaning a grill
Vulcan has an online site that allows you to down load the operation manual for just about every model... here' s link... their op manual looks pretty helpful!
Vulcan site
May 24, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Southbend 460DD-2TL Gas Kitchen Range Logo
Top Southbend Kitchen Ranges Experts
Bill Boyd
Are you a Southbend Kitchen Range Expert? Answer questions, earn points and help others
