Question about Sanyo PLC XP30 Multimedia Projector
Sanyo plc-xp30. Lamp turns on but has a yellow tint , in a circle that does not quite take up th ewhole screen. the color looks normal around the edges.
U need to unplug unit and turn on its back replace filter . blow out. sounds like its getting hot and dusty. u need to clean before u burn out your optical engine like i did.
Posted on Dec 02, 2012
5 Suggested Answers
  • 3 Answers
SOURCE: Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Posted on Feb 08, 2008
  • 4234 Answers
SOURCE: Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
Posted on May 08, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Posted on Jun 03, 2009
Hi, I have a Sony projector at my office PLC XU35 Multimedia projector, from today color show yellow and not clear. what is the problem? please explain
It is a Sanyo model.
See page 33 of the
http://cncms.com.au/SANYO-IMs/Commercial-Industrial/plcxu30_im.pdf
you can adjust several things like Color, Tint, White balance, Sharpness, Gamma etc.
Also make sure to perform regular maintenance listed on pages 38 and 39
Sep 06, 2016 | Sanyo PLC XU35 Multimedia Projector
Green blob in center of screen
If it is a nice circle and growing it could be a bad LCD filter.
Dec 02, 2012 | Sanyo PLC XP30 Multimedia Projector
Sanyao plc-xe31 displays yellow
the Blue Lcd panel was broken, the price of the panel is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mar 16, 2012 | Sanyo FOR PLC-XE31
Sanyo plc xu 22e,i get the red lamp indicator and the ready inicator but then the fans turn off and nothing happens. i can see the lcd through the lens and it displays sanyo and starts to count down from...
1,the lamp and the ballast is ok
2,it seems the motherboard is broken.
any questions, feel free to contact me
have a nice day!
Jul 30, 2011 | Sanyo FOR PLC-XE31
The bolb come on then shuts down is there a manuel way to reset the lamp.
To reset the lamp timer you must be able to access the on screen menus. If you can't and the projector shuts down before you can do so then the lamp is unlikely to be the problem, howevere this is how you reset the lamp timer.
Turn the projector on, and press MENU
Press the POINT LEFT/RIGHT buttons until you get to SETTING and then press SELECT
Press the POINT DOWN button and a red arrow icon will appear. Move the arrow to the LAMP AGE and then press SELECT
Select YES to reset the lamp timer.
Feb 20, 2011 | Sanyo PLC XP30 Multimedia Projector
Blue splonge on screen
If this is an LCD, it could be a torn ribbon cable on the red Opitical filter. It's a pain to get to and replace. It could also be a burnt Polarized glass filter on the red channel which is a little easier to replace. Check out www.pacparts.com for parts and prices. It may not be worth repairing.
Jan 04, 2009 | Sanyo PLC XP30 Multimedia Projector
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Benq lp 50 projector
If there is a yellow circle in the center of the image, and it is an LCD projector, then it is more than likely that the blue polarizing filter is burnt-out. I don't know where you can get replacements - I would like to get one myself for an aging Sanyo PLC-5605B.
Jan 29, 2008 | Office Equipment & Supplies
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Yellow tint square inset 2 projectors!
swounds like a default setting has been changed .. Try finding in the manual how to do a master reset to factory defaults
Apr 19, 2006 | Sanyo PLC XF45 Multimedia Projector
Open Questions:
Sanyo PLC XP30 Multimedia Projector Logo
164 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
