Question about Star 515ED Deep Fryer
I have a Star model #515 deep fryer I bought this from an auction and it was very very clogged with grease all over. I took the thing apart and cleaned it. I did not submerse any of the electric components such as hi-limit switch, thermostat or power/heating lights. I reassembled unit and checked current in off position and on position, every thing seems to be receiving power. Filled with oil and tested. Unit will only heat to approx 220 degrees. Hi-limit switch doesn't pop out or seem to stay in (floats back and forth) The thermostat does click on and off when rotating control. There are 2 heat couplers on this unit and I fixed them with ties around the element ( 1 has been replaced before and does look different? ) All connections are secure. The heating element does heat quickly to touch. Both of the thermostats are expensive, could of give me a diagnosis please Thank you
  • lonewolf2156 May 26, 2011
    no I do have 10 gauge wire way under 50 feet, and a red and black wire each of 120 each
    the element looks exactly like the one in the specs pictures?
  • 3,289 Answers
Hi - It sounds like you might not be providing the proper electrical requirements to the fryer. The 515ED is rated for either 208 or 240 VAC. When connected to a 208 VAC supply, it will require 16.6 Amps to produce the rated 3455 Watts of heat. When connected to a 240 VAC supply, it will require 19.2 Amps to produce the rated 4600 Watts of heat. Either 208 VAC or 240 VAC supplies would require a 30 amp circuit with #10 gauge copper wires at minimum - but even larger if the appliance had more than 50 - 100 feet of wire between the electrical panel and the appliance itself. The smaller wire over a longer distance would heat up robbing the appliance of the required power to run at full rating - that is why the size of the wire would be increased.
If the appliance name plate data is not visible or unavailable, you may not have realized that it requires 208 or 240 volts, and connected it to a 120 VAC supply instead. Ohms Law says when you double the voltage, you quadruple the watts. So, like wise supplying 1/2 the voltage would cause the wattage to fall to just 25%. In this case 850 watts (at 208 VAC) or 1150 watts (at 240 VAC) - both are significantly less than a typical blow dryer or toaster (which clock in at around 1800 watts).
The other issue is the potential for the previous owner(s) changing the heater elements to some value significantly lower than the originals (for who knows what reasons). Without knowing the history of the appliance, it is a little difficult to know for sure without obtaining the part numbers or electrical ratings of the heaters.
I hope this helps and good luck. Please rate my reply. Thanks.
Posted on May 25, 2011
  • Steve May 25, 2011
    Official data direct from Star Manufacturing can be found at http://www.star-mfg.com/documents/spec_s...
  • Steve May 26, 2011
    The #10 gauge copper wire will be bare minimum. The next size down (#12) is rated for 16 amps - not 16.1 amps, maximum. The #10 is rated for 24 amps, maximum. Use of the #12 or smaller wire is a code violation and more importantly, a fire hazard. Since there's less than 50 feet - you should connect the fryer with #10 wire to be legal and safe.
    When you say " A red and black wire of 120 each" - you must be measuring 120 volts from each of the wires one at a time to the ground and / or neutral wire(s). You must measure between the red and the black wire. That voltage must be 208 or 240 volts. As you might guess, use of a simple test light will not tell you the voltage. A meter or wiggy should be used to determine the voltage that is present. The red and black wire should be connected in the electrical panel to a double pole, 30 amp circuit breaker - or two adjacent (for 208 or 240 volts) 30 amp fuses. Let me know what you measure.
How do i stop the grease from boiling over
Make sure there is no water in whatever you are placing in the grease....grease and water together equals bad boil over.... the water turns to steam rapidly and very bad things happen...
heatman101
Oct 11, 2010 | Rival CF105 Deep Fryer
Pitco-matic filter system always getting clogged and won't return grease to fryer
Make sure that the filter system is correctly assembled so that oil impurities wont enter pipes and clog the system.
Apr 14, 2010 | Pitco Frialator SG14 Deep Fryer
Need wire diagram
A manual can be downloaded from the following link, the wiring diagram is located toward the end of the manual.
http://www.star-mfg.com/documents/Manuals/Star/Fryer/Electric/C_530TD_530TED_-_2M-Z6600.pdf
Hope this helps, please rate me!
May 07, 2009 | Star 530TD Deep Fryer
Deep fryer won't turn on
I had the same thing on a Presto deep fryer. I removed that back cover and traced the wires from the AC inlet. One lead goes to a switch that activates when you slide the heater into the case so the heating element will not turn on if it is not in the case. I removed the switch, pushed it in and out a few times, verified that it works with a multimeter, reassembled everything, and "presto", it works. Maybe I was lucky, but it worked for me.
Aug 21, 2008 | Kitchen Appliances - Others
Star deep fryer.
Those thermostat bulbs are the thermostat and hi-limit bulbs.They need to be secured to the fryer.The hi limit is tripping out because its sensing that the oil is too hot.Even though the oil isnt that hot the hi limit thinks it is.
May 15, 2008 | Star 530FD Deep Fryer
Deep Fryer stopped working.
I had the same problem, but I fixed mine!!!! Make sure that the part with the control panel is locked in. It you just sit it in, it won't come on. You must lock it in on the side.
Apr 08, 2008 | Kitchen Appliances - Others
Star 515ED Deep Fryer Logo
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
