Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Won't come out of power saving mode
My FPD which I have won't come out of power saving mode. It stays dark as soon as I switch on the PC so I cannot boot it in safe mode. Is it the monitor? Should I just replace it? Just before this problem began last night, my keyboard started acting weird. I have a new wireless keyboard and mouse and I could access the F keys but not the main keyboard(could also use the mouse.) Anyway, I would be much obliged to any light you could shed on the subject as now I have to use my laptop since my Gateway desktop is useless.
  • 1,800 Answers
Chek the connection cable between the CU and the Monitor and the power supply cable of the montor or give another outlet
Posted on Aug 16, 2008
SOURCE:
My laptop won`t charge unless it`s dead and in an outlet I have not used yet with my laptop
Go to control panel, click on Pen and Touch and follow the instructions. Click on the battery icon, you will see your power options, check on each one to set your power options, I suggest you set it to battery saving mode or any mode you prefer.
Nov 07, 2013 | ASUS Computers & Internet
Camera won't remain on
It's probably a lens related problem. Blow through the lens to remove any debris stuck inside. Or tap your camera repeatedly while the lens is facing the ground.
Aug 14, 2012 | HP Photosmart R927 Digital Camera
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
How do I get the monitor off power save?
it will allow you to enter the selection screen to pick safe mode, you just need to keep hitting the F8 key repetedly as soon as you hit the power button to turn the pc on.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Gateway FPD 1510 15.1" Flat Panel LCD...
My monitor shows image immediately when switched on but just as soon the image appears the screen of the monitor goes dark after that need to off/on the power switch three to four times before the image...
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Jun 18, 2010 | Dell E193FP 19" LCD Monitor
Computer will power up, but FPD 1730 screen stays dark, says "power saving mode" How to cure??
Its setting problem just fallow this stapes for the same.
Go to Start > Control panel > Power options Properties >
Turn off monitor: Never
Turn off hard disks: Never
System standby: Never
Apply > Ok
After that your issue will resolve.
Thanks
Abhay Singh
Nov 16, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
201 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
