Question about Compaq Presario Notebook
It won't go online but the other laptops in our house is online working fine...I tried rebooting it back to factory settings and it won't reboot what could be the problem it is showing all the icons and when you go to get online it say's that we are not connected but I know im doing it right and when i sign onto wireless connections it also shows connected
  • 386 Answers
First thing you can do is a ipconfig /release /renew on the laptop that isn't connecting.
to do that, go to:
Start>All Programs>Accessories>Command Prompt.
Once thats open, type in ipconfig /release
note, there should be a space between ipconfig and /release and renew
your ip address should come up with 0.0.0.0
Now type in ipconfig /renew
remember a space between ipconfig and /renew
You should see an ip address of 192.168.XXX.XXX or 10.10.XXX.XXX something like that, depending on your network settings.
if you do, you should be able to get on the internet.
If you see an address of 169.254.XXX.XXX
Then it would be best if you powered off the Modem and the Router.
First turn off the Router, Next the Modem.
Power back on in reverse order and see if it is able to connect then.
If all that fails, You can reset the router and see if it will connect then.
You should have a reset button on the back of the router.
Remember once the router is reset, you'll have to redo the security settings.
Hope this helps!
Please Rate;)
Gary
Posted on May 25, 2011
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
Keypad won't work sideways on my zte warp
Try resetting the device to factory defaults and that should resolve the issue. Please make sure that you have a back up of all the information and the SD card is removed before resetting it.press Menu Key > Settings > Privacy > Factory data reset > Reset phone(Don't check Erase SD Card)> Erase everything. The phone will reboot automatically.
Jan 15, 2013 | ZTE Warp
I have an Acer one aspire that won't start. I keep
Dear user,
Please try to restore it to factory mode or re-install OS
Aug 22, 2012 | Acer Aspire One PC Notebook
Hp laptop has blinking red square above touch pad, comp. won't allow for reboot or restoring to factory conditions
If you do an illegal shut down which is power off by holding down the power switch for 8 seconds. The HP computer will then boot with the scandisk program, which will restore your hdd to perfection. Windows XP or later now use 'system restore' to rearrange registry from a previous calender date that the computer used to work perfectly.
Feb 09, 2012 | HP Pavilion dv2911us PC Notebook
Can't get Router to connect to the xbox360 it is telling me that I need a wap/wap2 pass phrase. Where do I get this from. It was working fine the other night. And it dropped everything in my house....
Only option is to press button on the router ''reset''
Press and hold it for 30 seconds and release it. This will set everything back to factory settings.
Jul 29, 2011 | Linksys WRT120N Router
The problem with my laptop is that I rebooted the computer and everything went back to factory settings, I cannot link up with internet using wi-fi capabilities, I press the wi-fi button on the right of...
What do you mean went back to factory settings? Are you referring to the bios settings? Or other else? If you are referring to the bios settings, and everytime you change the bios and rebooted, then back to factory settings then your problem maybe the cmos battery. You can change it and try if everything works fine. And maybe you can't connect using wifi because it is disabled in the bios settings or if not you got a defective wireless module. Hope this will help pal. Maybe you should elaborate your situation more detailed as what is really happening to your laptop,
Aug 29, 2010 | Acer Aspire 5735 Notebook
Network is "Hidden"
Try a router reboot.
1. Unplug the Router
2. Shut down and restart the laptops, unplug the XBOX for 20 secondes even though its working.
3. Replug the router.
If this doesnt work you can try resetting the router to the factory settings.
Follow the link below for step by step resetting procedure.
http://www.geckoandfly.com/5890/reset-d-link-router-factory-settings-and-default-password/
Jun 13, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Im trying to reset my acer to factory settings and evreything i try will not work. how do you reset the laptop to its factory settings
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
Jun 10, 2010 | Acer Aspire 3000 Notebook
Compaq Presario Notebook Logo
133 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
