Question about Boating
Tohatsu outboard 15hp 2 stroke was running great, suddenly won't power up under load. new tank, new hose, new fuel,new plugs, carb cleaned all ports clear no change in operation. Engine will start fine, idol fine. when any throttle is applied the engine boggs down, runs very rough and provides no power or increase in rpms. Squeezed fuel bulb with no change. Using a rag removed the spark plug wire, felt the spark, engine soon quit. tried both cyls.
    Novelist:
  • 184 Answers
First: with flashlight or mirror look down the carb- with switch off- and gear and throttle wide open and see what the butterfly valve inside there is doing. It should be parallel to the air flow.
If not you need to find the actuator am and be sure it moves with the control and opens all the way.
Next make sure the timing plate under the flywheel moves at the same time the throttle is opened. Then -using timing light- see if the timing is set to the correct "wide Open throttle" - this is a 2 man job done at sunset with good marks on the flywheel (don't wear a tie). This can also be done static by running it out of gas and using the pull cord- if it has no safety interlock.
Last- and the saddest part- is the compression test. The strength of the reading is not as important as the similarity. When I worked on Chryslers, they were bad if the two readings were as little as 8# apart. The minimum reading should be over 80#.
Posted on May 26, 2011
  • tomkaren428 May 27, 2011
    Very good info. Compression 109/110. Butterfly open/correct. Spark test jumps 1/2 inch. Timing may be the issue, check that this wknd. Not really sure how but will figure it out. Thank You!
I have 4sroke 4 hp Mercury outboard and gas is leaking from vent tubes on top of carb. Why is this happening and best way to repair
A stuck float valve in the base of the carb, or a particle of dirt in the float needle jet. Are you using ethanol based fuel and do you have ethanol rated fuel lines? Take the carbs off and clean them.
4 stroke 4 hp mercury clean carburetor Google Search
This is similar
how do adjust the fuel mixture on tohatsu 9 9 hp 4 stroke
Jul 08, 2018 | Mercury Boating
I want to know if a tohatsu 2 stroke 5.8 hp outboard can work with external fuel tank?
Chris,
Yes it can. The built in tank will have a hose coming out of it and going to the carb. Disconnect the hose from the carb and connect a comparable size hose from the external tank to the carb. One thing to note, you will want to make sure the new tank to carb hose has a primer bulb on it. Engines produce vacuum while running which will draw fuel to the carb. However once shut off, the vacuum is lost and the line will need to be "pumped up" i.e. primed to get the fuel to the carb for startup.
Fred-
Aug 05, 2016 | Boating
Gas flowing out of the top of carb. this is a 9.9 mercury 4 stroke outboard motor.
this can happen when the float in the float chamber of the carb. jams or "grot" gets in the way of the seal that pressure from the float should create to stop fuel entering the carb. An easy fix, if this is the cause. Unscrew the float chamber be, careful of the gasket, and clean inside, check float for freedom of movement. I prefer paper/fibre gaskets. Good to keep a spare in your kit.
Hope the above was of help.
Feb 28, 2016 | Mercury Marine 15hp & 20hp 4 Stroke...
Misfire on Tohatsu outbaord.
one would assume so but as you have not mention if it is a 2 stroke or 4 stroke , that assumption would possibly be wrong
2 strokes use reed valves between the carby and manifold and the crankcase and in outboards these reed valves can split and not function properly especially at higher prms
these reed valves allow fuel mixture in when the piston goes up and shut off when the piston comes down creating a pressure in the crankcase which pushes the mixture up the bypass of the cylinder into the combustion chamber
if these reed valves are not working properly or the crankshaft seal are failed this compression in the sump doesn't occur properly and engine running problems result
IF it is a 4 stroke the soaking the carby in cleaning fluid will only remove 1/2 the problems
It is best to have the carby fully overhauled by an accredited outboard mechanic as there will still be corrosion in the body and mixture passages that cleaning fluid alone will not remove.
have the ignition system checked as it may be an overheating component ( coil --ignition module) that is causing the failure.
Aug 11, 2015 | Boating
1996 Evinrude 9.9hp, 2-stroke power loss.
Checked the vent cap on the fuel tank?
Check if it runs again great after pumping fuel...
Check when it drops power if both spark plugs still sparks...
You can have a bad coil or cdi...
Jul 25, 2017 | Boating
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Aug 28, 2009 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Boating Logo
1,146 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
