Question about Bose Audio Players & Recorders
When listing to my music on my Bose A2 audio headphones, I can hear music playing but i can barley hear the singing from the artists, I cant figure why the sound of the singing has gone away all of the sudden. Its not the music file, you can hear the singing in the song when it when it's played through my computers speakers.
  • 5 more comments
  • camely90 May 25, 2011
    It's defiantly the second issue. I had the jack as far in as it would go and nothing worked. I am not familiar with the cable or how to replace the jack, so what did I need to do?
    It turns out that the cable was loose on the headphones, which I had no idea could be detachable, I figured this out by calling Bose, thanks for you help!
  • Emil H Jul 17, 2013
    I just had the same problem, the audio sounded distant and compressed. Make sure BOTH ends of the headphones are firmly seated.
  • Anonymous Mar 18, 2014
    Only the music in the song is playing there is no singing during the song, how do i fix?
  • russ r
    russ r Jun 19, 2014
    I have the same issue...and if you press the center button of the volume up/down control located on the headphone cable itself, the voice comes back into the mix.
  • russ r
    russ r Jun 19, 2014
    I have the same issue - the voice is very low in volume but the music is normal. When I press the center button of the volume up/down control (located on the headphone chord) the voice is back to normal.
    President:
  • 1,851 Answers
First of all I think that you mean AE2 headphones. This problem is due to a faulty connection of the outer ring (ground point connection) at the headphones jack. Check the connector from the headphones to the laptop (or desktop, speakers e.t.c.). Is it firmly connected? Sometimes needs a little more pressure to go deep inside and this is the solution. In case the above didn't help you, maybe there is an internal cut at the connection from the headphone's cable to the headphone's jack. In this case you have to replace the jack.
Check for the first case, that is the easiest one and post me the results. Also clarify me if you are familiar with cable connections in order to guide you how to replace the jack.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 25, 2011
  • Stelios
    Stelios May 25, 2011
    Let's clear up all the other cases. Try the headphones at another audio system with a suitable headphones output (laptop, mini - midi stereo system, mp3 player etc). If it's possible try another set of headphones at the same source that you used the BOSE AE2. Is the problem existing on these headphones?
    Waiting clarification, don't hesitate to post.
    Thanks and regards
    Stelios
    direct fixya link:http://www.fixya.com/users/technical114
  • Stelios
    Don't mentioned it, whenever you came up with any problem don't hesitate to ask Fixya's Experts help.
    Thanks and regards
    Stelios
I can hear audio from out side of my headphones
They are semi closed headphones, you can get closed type that keep the sound inside the headphones but these are not like this.
You need a different pair of headphones to suit this purpose.
Mar 04, 2012 | Bose QC15 Headphones
Hi I am having problems getting vocal sound from my bose speakers when I play a song. I can hear the music part well but can't hear the person singing. I have an Asus desk top. Please help.
Click start control panel administrative tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device
Hope this helps you
Oct 03, 2011 | Bose Companion 2 Computer Speakers
The Mic will record, but when i plug in my headphones into the the mic in the front...it still continues to record when speaking, singing into it...but i cant hear the music (instrumental) in the...
This could be due to the output volume and monitor mix are turned too low. You can fix this by adjusting the input gain levels in the ASIO settings menu.
Apr 07, 2011 | M-Audio Producer USB Microphone with...
When I listen to my music you can hear the instrument, but you can't hear the singing. HELP.
Hi, when your using an ear-phone and you hear only the instruments alone, it means that the ear-phone is bringing out a mono signal(always have one ring at the tip of the jack),but if it was two rings,then you will have a stereo signal that will allow you to hear both the instruments and the voice..
Hope that helped..
Thanks for using fixya.
Oct 21, 2010 | Bose in-ear headphones - Black with...
When i turn the volume up past a certain point the music stops playing and all i hear is a scratchy noise every couple seconds
This is usually due to the headphones or speakers not being able to play back the audio past that point, try a different set of headphones, the earbuds might be burnt out. some earbuds **** and cant play sounds past a certain dB the general dB levels tolerated without distortion are about 104-110 ish, but if you are listening anywhere near that your gonna hurt your ears. tests have shown that audio levels past about 90dB will seriously damage your ears after prolonged usage. Generally get nice in-ear ear buds with noise cancelation and never move your audio past 90% to clearly hear the music without damaging your ears.
I got my girlfriend some Jbuds J2 and they are great and i prefer them over my 200$ bose ear buds. check amazon they are about 14$ the J3's are around 24$
Nov 04, 2009 | SanDisk Audio Players & Recorders
G-Tec Digital Audio Player
Well, this isnt really a solution, but, how did you download the songs on the G-TEC, I cant even figure it out!
Feb 28, 2008 | Digital Audio NAP256 MP3 Player
No vocals!
Maybe your headphones are pulled out halfway.
Feb 11, 2007 | SanDisk Sansa m240 MP3 Player
1,380 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
