Question about Behringer (UCG102) Sound Card
After installing the drivers I cannot find the asio control panel. Ive tried downloading asio4all driver and it didnt work either.
  • Behringer Master
  • 27,725 Answers
If you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Posted on May 25, 2011
When I record with my m-audio mobile pre USB, there is no latency issues with recording but there is a delay in the headphones if I turn them up to hear myself while recording. How do I fix this? I'm using...
Have a read at this article. I assume you are using ASIO4ALL if not then you should.
http://www.image-line.com/support/FLHelp/html/recording_audio_USBmic.htm
Specifically this part:
Note about latency: USB microphones generally only allow you to hear the sound being recorded after it has passed through FL Studio. As the latency of USB microphones depends on the ASIO4ALL latency settings, there may be a troublesome delay between the sound made and it being reproduced from your speakers or headphones. For example, low latency monitoring is particularly important to vocalists as high latencies cause a distracting echo effect. The only solution to this problem is to lower your buffer length settings (there are limits) or obtain a new soundcard with direct-monitoring.
Feb 15, 2015 | M-Audio Computers & Internet
Reason software can it produce sound without the internet
Reason Software produces sound through your computers sound card & speakers, but your system must meet the minimal system requirements listed below:
Mac OS X
Core Audio compliant audio interface or built-in audio hardware
Windows
Audio Interface with ASIO driver
Instructions to install ASIO driver if required:
download installer from this link:
http://tippach.business.t-online.de/asio4all/downloads_11/ASIO4ALL_2_11_English.exe
double click the installer & follow instructions, please ensure you restart your computer after installation.
Jul 14, 2014 | Propellerhead Reason 5 Educational Version...
ASIO driver for xp
If you're not using ASIO4All then do, if you are getting a time out on the download the problem is with the site or your ISP most likely. Try another site.
Nov 17, 2013 | Behringer Ucg102 Guitar Link USB Audio...
I've got a new Blue Snowball mike that worked great out of the box, but now, a week later, it just gets a "device not recognized" message when I plug it in. I've tried rebooting, and...
I had the same problem with my PC and went to http://www.asio4all.com/ where I downloaded and installed the driver and it worked!! I found the site by reading this FAQ (see below) at Blue under Snowball.
(But I still have the same problem with my MAC).
"If you should experience any problems getting the program to recognize the mic, Adobe recommends the following: If the device does not allow you to record, then your microphone is not being detected as a valid input device in Premiere Elements. You can use an open source program called ASIO4ALL, which is a device driver that essentially wraps existing WDM devices, like USB microphones, as ASIO-compatible sound devices. Use the following steps to utilize this tool:
  1. Quit Premiere Elements.
  2. Visit the following web page and download the latest available version of ASIO4ALL: http://www.asio4all.com/
  3. Install the software, and restart the system if asked to do so by the installer.
  4. Make certain that your microphone is plugged in.
  5. Launch Premiere Elements. Go to the 'Edit->Preferences..>Audio Hardware' menu option. For the Default Device, choose the ASIO4ALL option. Click the ASIO Settings button, then select your microphone from the list of devices, click Exit, and then click OK on the Preferences dialog. Close and then restart Premiere Elements."
Dec 28, 2010 | Blue Microphones Snowball Professional...
Just purchased behringer u-control uca222. When first plugged in the power led came on. Downloaded the midi driver at the behringer site and attempted to install. Power led went out then the midi drivers...
The UCA222 is a USB AUDIO Interface, not MIDI.
You want to download the ASIO driver(s) and install those again. You then have to go to whatever audio software app you are using, and 'set up' the ASIO drivers within your audio software itself (read the manual or look at some of the headings under Preferences or Settings in the software window itself).
Also go to the Audio Settings panel and configure your Audio Ins / Outs, make sure they are selected and 'enabled'. You should see Behringer USB listed when you click on the audio out tab. Just click on it with the mouse button and release.
You also may have to go to the ASIO Control Panel (again from within whatever audio app you are using) and tweak whatever settings are there. Make sure the ASIO driver is selected (not the MS Win or Realtek or whatever), and check that the audio outputs are likewise enabled there.
(Some apps won't output any sound while you are adjusting the Control Panel settings etc, so you may have to adjust the settings, then close the panel, before you'll be able to test for audio output, then if it doesn't work, go back into the panel and adjust some more and try again.)
If you are trying to control a VST plugin or VST Instrument via MIDI, you just need to go into your audio app's Midi Settings panel and likewise make sure your Midi controller kbd (or other Midi source) is selected and enabled, and that the appropriate Midi channel is enabled (or you can just select Omni Mode and it will listen to all Midi channels).
Of course you must have some sort of MIDI interface to connect your keyboard to your computer. Many new kbds have USB in which case it will send/receive midi via USB (tho you may have to install the proper drivers for your specific keyboard first. - they will be on your install CD that came with the keyboard or available on the internet).
Good luck! Hope some of this helps.
Mar 19, 2010 | Behringer U-CONTROL UCA202 USB-Audio...
ASIO Driver give chopper sound in fl studio
You might wanna try to increase the ASIO buffer size (perhaps a lot) ...
And if that doesn't help, you might wanna try the www.asio4all.com driver
Jan 03, 2009 | ASUS Intel 440LX Chipset P2L97-DS...
Not soppot asio in fl studio
Try a different ASIO driver. I would say that the sound card that you are using does not come with an ASIO driver so the software can't use the card correctly. I recommend ASIO4ALL. It is free to download and works with almost all soundcards and audio devices in Windows. You can get it from www.asio4all.com.
Best of luck.
Cheers
Dec 30, 2008 | Creative Labs Ensoniq ES1371 Sound Card
It says I can not record pick the asio duplex but i don't know how
What recording software are you using? What version of Windows are you on? The ASIO driver for the Lambda should have been installed when you loaded the software that it came with, and if so there should be a control panel that will allow you to select that. The other option is to use ASIO4ALL. It is a free ASIO driver that works really well for most sound cards and software instruments and recording software like Cubase, Nuendo or the many other programmes out there.
If you need more help let me know.
Cheers.
Dec 22, 2008 | Lexicon Lambda Usb Desktop Recording...
Canecting US122 with Sonar HS4
Hey there,
Try the latest US-122 driver (3.4.0), you can get it here:
http://www.pcmusic.org/software/version.php/lang/en/id/10422/
There might be a latency problem with the Asio4all driver too, try the US-122 16bit or 24bit driver, they are actually Asio drivers.
Also navigate to Windows Control Panel and make sure that a Windows Media Player Update hasn't minimised the Wave Control Sound.
Good Luck and have fun
Chris (ziraffa)
Mar 02, 2008 | Tascam US-122 USB Audio/MIDI Interface...
Behringer (UCG102) Sound Card Logo
538 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
