Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
How much can i sell 2 10' sony subs in the box for
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
3 subs in 2 box 1 1200 watt Sony explode amp
Most sony amps run at 4 ohms mono. There is no way possible to get your subs even close to that. you need to either remove a sub from the equation or get a 1ohm stable amp.
Oct 20, 2014 | Car Audio & Video
Lost remote for dynaudio sub 500 need code
that could be a hard one you have to find the search procedure to each remote and try searching the code the other thing you can do is buy a Sony learning remote and go to where that sub is sold borrow their remote for a minute and have the sony remote learn the commands that the sub remote has by putting them together with the remotes learning procedure. Or just buy a remote for that sub if they sell the remote by itself. their phone is (630) 238-4200
Apr 07, 2014 | DISH Network IR Remote Control
Hi i have a bnps102 subwoofer system along with a pyle 1400 watt amp. my amp is getting power to it hence the green light lighting up and the subs sounded great but last week during a song they both...
You are right about the scratching sound meaning the speaker is blown. The other one by it not playing it could mean the voice coils in it are blown or burnt.The safest way to check the speaker is to connect it to a standard 9 volt battery and listen for a popping noise when you make the connection and look the see if the cone stands up as long as the connection is made n returns to normal and no noises when disconnected from the 9 volt battery. To test this while the sub is plugged in to the amp but out of the box move the cone as far in and as far out as it will go. If it comes on while u hold it on either one of these positions but when released it goes back to not playing then the coils in it are blown or burnt and is no longer any good. As for selling the box its on you, aim anywhere from 2/3 to 1/2 the price you paid for it minus the speakers.
Aug 22, 2011 | Pyramid Subwoofer Box Dual 10" 1000w ...
1 subwoofer stopped working in a box for 2
Hello mccanello55,
You need to remove the subs from the box in order to check the internal box wiring. First, make sure that the wire going from the nonworking sub terminals to the enclosure terminals is OK. Then check the "braided" leads on the back of the terminals going to the speaker cone. If the wiring all looks OK, remove the wires from the sub terminals, and use a multimeter set to the lowest ohm range and check the resistance across the subs terminals. You should read somewhere between 3-4 ohms. If the meter reads infinity (that is no reading at all), then the voice coil is open. If it "pegs" (reads "0"), the coil is shorted.
Either open or shorted means the voice coil is no longer working.
I could not find any replacement parts on Sony's support page, so it's most likely that they don't even repair these. They probably just replace the sub if it's under warranty, and if it's not under warranty, they probably recommend that you buy a new one.
Hope this helps.
Apr 13, 2009 | Sony Xplod (P589) Car Subwoofer
Orion hcca 250
i can make this relatively simple.
2 stages:
Stage (1) wiring the Sub inside the box;
Unscrew the SUB from the Box, (& undo the wires)
Connect both +Positive terminals on the SUB to the +Positive terminal on the inside of your BOX.
Connect both -Negative terminals on the SUB to the -Negative terminal on the inside of your Box,
Then screw the SUB back into the Box.
u Have just wired yr sub in parallel. any Amplifier will see it as 1woofer with 1OHMs resistance.
Stage (2) bridging your amp
(please check Amplifier instructions on which terminals to use)
generally you use "LEFT -Negative" and
"Right +Positive"
and connect to the corresponding terminals on the Sub Box.
Hope that helps someone.
Feb 25, 2009 | Orion HCCA-D5000 Car Audio Amplifier
I want to sell my Pioneer 10'' 350W BAND PASS BOX Car Speaker
Search google the model of the pioneer, and try and find a used or new price and go from there.
Boxes are cheap and can be picked up locally anywhere for around $20-30 bucks used so dont charge a rediculous amount because it has a nice box.
For instance if your sub was $100 new. and then you bought a box for $30-50 new.
i would probably only sell it for $80 Max that is in PERFECT condition not blown or anything.
nobody will buy something that is $20 cheaper than retail priced especially if it is used.
I have been in sales and online sales for years.
Selling used items your prices stay low so the sale can happen. Priced to high people will just go buy it brand new if they want it.
I would recomend selling through Craigslist.Org. Local and easier than Ebay
Feb 10, 2009 | Pioneer Car Audio & Video
Support Question about RMS
you are going to need an amp that can supply the right amount of rms power to make it sound good. these sony subs are rated for 380 watts rms. so in order to find an amp that will supply two, you must multiply that figure by two. so you will need an amp that can supply around 500 to 750 watts continuously (or rms). also you are going to want an amp that is either class d or class ab rated. these amps are built to push subwoofers exclusively and will give you the best efficiency and sound out of your subs. you will also want to get an amplifier is a monoblock amp, and not a stereo amplifier. make sure the amp can put out that rms rating at 2 ohms as two 4 ohm speakers equal 2 ohms wired in parallel. i have a kenwood kac9152d that puts out about 2000 watts max at 2 or 1 ohms (900 watts rms) that i used with my two sony xplod 10's for about 2 years. it was kick ***! now i dont know if you need that much power but they will handle it as long as you dont push them too hard for long periods of time, otherwise you might end up blowing them up! (depending on the box size that is, and the quality of it as well...)
i have years of car audio installation experience and can help with setting up and wiring any mobile entertainment system you can imagine. may i ask what kind of music you listen to and what kind of box do you have for these subwoofers?
if you have any questions email me at thadoggma420@hotmail.com
Jan 22, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I want to buy a subwoofer for my 30W jvc shelf system
There many S/W that will fit your needs. Try the Wal-Mart Model #: L8SW
May 07, 2008 | Audio Players & Recorders
Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
