Question about Olympia Monica 2 Typewriter
Olympia es 95 typewriter carriage not moving. all key entries try to type in the same spot.
  • 106 Answers
SOURCE: No Typing, but Powers Up, brother ax-25
open your typewriter and muve prinre left-rigt, you have a prnters jam or power suply module is not ok too low dc voltage
Posted on Feb 04, 2008
JUSTOLDJIM
  • 478 Answers
SOURCE: Olympia international E-R12 typewriter
electronic typewriters do not reverse. chang the cartridge.
Posted on Jun 04, 2008
SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Posted on Sep 02, 2008
JayBlair
  • 328 Answers
SOURCE: My typewriter carriage doesn't move along as I type.
Does the carriage move if you depress the tab key or space bar? Is there any pull on the draw band. Maybe the main spring is broken.
Posted on Sep 18, 2009
  • 14 Answers
SOURCE: My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Posted on Oct 14, 2009
How do I increase the area where I can type?
Press margin release key, move carriage using backspace to where you want the left margin to be and press left margin set key. Repeat for the right margin, use space bar to advance the carriage and press the right margin set key instead.
Sep 10, 2014 | Olympia Startype 3 Typewriter
I have an Olympia Progress manual typewriter. It seems to be in good working order, well oiled and good action in the keys, except the carriage won't advance when I type. I don't believe the...
try typing with a little pressure on the carriage (push with right hand to the left) if it work like that then the carriage pull cord may be broken
Apr 23, 2013 | Office Equipment & Supplies
My old manual Olympia typewriter always stops in the middle of the carriage when typing. If I hit the shift key it will move forward and I can continue to type. What is the mechanism that makes it s
The carriage is touching the cavers it need the flat rubber washers that are between the case and the frame look at the bottom of the typewriter remove the screw slip in a new washer and replace the screw do the same on the other side
May 21, 2012 | Olympia Manual Typewriter
Typewriter problem
IF THE CARRIAGE IS NOT MOVING LEFT OR RIGHT, CAN YOU PUSH THE CARRIAGE TO THE RIGHT OR LEFT??? OR IS IT COMPLETELY STUCK. YOU CAN TRY CLEANING THE SILVER SHAFT THE CARRIAGE SLIDES ON AND LUBRICATING THE SHAFT WITH A LIGHTWEIGHT OIL, WHEN YOU PRESS THE KEYS DO THEY WORK.???
Mar 18, 2010 | Olympia Mastertype 3 Typewriter
Needs oiling, where and with what product,
Does the carriage move when other characters are typed.???
You may just have the one defective key.
Jan 08, 2010 | Olympia Office Equipment & Supplies
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
What Ribbon model # fits an olympia ES70I typewriter?
ES 70i ribbon:
OLYMPIA 9400 (carbon)
OLYMPIA 9300 (fabric)
OLYMPIA 9420 (multi-strike)
9400 (carbon) best for professional crisp type
Sep 01, 2009 | Office Equipment & Supplies
Carriage remains stationary when typing. Is there a way to unlock
Mant portables have a lock to hold the carriage in place while in the case, on the rt. or left sides below the carriage.
Hope this helps
DickyO
Apr 14, 2009 | Olympia Office Equipment & Supplies
Olympia Monica 2 Typewriter Logo
102 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
