Question about Fluidmaster & Fits-All Faucet Connector
After tank fills up, water continues to flow a little. How do you fix it?
  • 32 Answers
Is the water flowing into the overflow? If so adjust the water level. Have you checked the shut off seal inside fluidmaster? If you just installed could've jogged some sediment lose in the line and plugged the seal if older could have a bad seal.
Posted on May 27, 2011
3 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: after tank fills up, water continues to flow a
Replace the top cap of your fill valve, or just the fluidmaster seal disc. Here is a link to the Fluidmaster fill-valve Instructions.
Posted on Sep 06, 2010
  • 117 Answers
SOURCE: The tank is filling very
Fluid master comes apart at top.Turn counter clockwise to unsnap .You will see water valve seal. take seal out and clean out any grit. reasemble and should work. hope this helps.
Posted on Dec 25, 2010
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
How do I fix my bunn #053213cs from leaking from the bottom
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Jun 04, 2014 | Bunn VPR Coffee Maker
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
When putting gas in my 2004 Kia amanit the fuel nozzle kicks off. How do I locate and fix the problem
HI Bridgette,
Due to the different shapes of fuel tank filler necks in cars & trucks, it may be necessary to vary one or more things to allow fuel to flow uninterrupted until the tank is really full.
The main problem can come from the new "vapor recovery" gasoline pumps. These pumps and hoses actually recover gasoline fumes from your tank as the liquid gasoline displaces the air / fumes in the tank is it is being filled. If gasoline flow is started at full blast, it can splash back slightly, causing liquid to be pulled back by the pump - so it shuts off. So, start with a slow rate of filling and gradually increase flow rate to maximum over 5 to 10 seconds. If it still shuts off, try some of the suggestions below.
First, don't fill at maximum flow rate from the pump - that is, don't set the nozzle for wide open. Select one of the other "latches" on the handle instead of the fastest flow and let the tank fill entirely at this rate.
Second, you should experiment a bit with the length of nozzle that you push into the tank's filler neck. If you push it in too far or too little, the pump nozzle can do what you're describing.
Third, try twisting the nozzle slightly so that it doesn't hang straight downward - a little to the left or right may provide a solution.
Lastly, try a different gas station. Their pumps may not be so picky with your tank's filler neck.
Jun 14, 2012 | 2004 Kia Amanti
A stink bug climbed in the water chamber and we can't get it out. is there a solution?
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
Mar 07, 2011 | Rowenta Professional DX8800 Iron
Sep 06, 2010 | Fluidmaster & Fits-All Faucet Connector
Water flow problem
2 things it could be. Bad flapper seating or back siphon.
1) visually check the flapper. Is it worn, cracked, or not fully seating because the chain might be too long and preventing a good seating?
2) IF the flapper is good without anything blocking it open there, then you have back siphon. Make sure the small hose that goes from the fill valve into the over flow tube has an high arch. If the arch is too low, after the water is cut off the gravity will back siphon water out of the tank.
Mar 19, 2010 | Home
After flushing, water fills up tank and continues
Your problem is the water fill valve. Check this link.http://www.rd.com/17646/article17646.html
it's not the flapper or flush valve.
Mar 05, 2010 | Home
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Fluidmaster & Fits-All Faucet Connector  Logo
368 people viewed this question
Top Fluidmaster Plumbing Experts
Jim Goldsmith
Jim Goldsmith
Mack Baxter
Andrew Bugbee
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
